Speed Issue...Pls Help!
- Speed Issue...Pls Help!
23-12-2010 5:10 PM
I am having really slow speed.
Ticket - 38221193 raised yesterday, but no help yet.
Having download speed less than 300kbps...tried everything mentioned , no improvement yet...
can you please help?
thanks,
Maneesh
Re: Speed Issue...Pls Help!
23-12-2010 7:44 PM
24-12-2010 2:49 PM
Looks like you had some intermittent issues when you first connected. This will have brought your profile down with the BT systems. Your sync rate is really low at the moment. Please have a look here for some tips how to resolve this. We won't be able to raise a fault yet because you are still in your 10 day training period, but I would suggest carrying out all the checks in the previous link thoroughly.
Jojo
25-12-2010 12:31 AM
i have tried all the steps, but could not find any problem.
Really having unusable internet speed, never experienced with any of my previous ISP's.
This is nightmare!
see below...having better upstreams speed than downstream explains the situation i am in...
thanks,
Maneesh
27-12-2010 2:46 PM
when you say you have tried all the steps, do you mean that you tried different configurations but didn't see an increase in speed?
If that's the case then you wouldn't see an increase in speed. It is the connection rate we need to see improve. Can you connect to directly your test socket making sure you're not using extension cables in between so I can do some more tests?
Jojo
31-12-2010 10:30 AM
speed seems to be little bit better from yesterday onwards...
i will wait for few more days to confirm it though.
thanks,
Maneesh
01-01-2011 11:35 AM
My training period is over and the speed was ok for 2 days in those 10 days. Those 2 days in BT speed test shown my IP profile was set to 4000kbps. Again it is back to sqaure from yesterday onwards; Now the BT speed test is showing my IP profile is set to 350kbps.
I am getting speeds worser than a dial up connection. Even after waiting for 10 days of the so called training period...
04-01-2011 8:18 PM
05-01-2011 10:34 AM
I have been looking into this for you and see that your line has been banded. I would need to do much further investigations to find out what the cause may be and this may take some time. I note that you are due to have FTTP installed on Friday so I wonder whether this may be worth pursuing in these circumstances.
Jojo
05-01-2011 5:18 PM
The FTTP is just a trial,what happens once the trial is over? i dont want to get in to this situation once the trial is over.
i got this mail from plus net,
Now that your service has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed: 2.5Mbps
Current line speed: 0.35Mbps
See the current line speed. I am not able to use the internet most of the time with this speed (more often lesser speed) for the last 2 weeks.
05-01-2011 5:28 PM
Even once the trial ends you will still be able to stay on it as long as you want.
Jojo
09-01-2011 9:41 PM
i am on FTTP trial now and the situation has improved
Before
After
Thanks again for looking in to this....hope this speed stays!!!
Rgds,
Maneesh
10-01-2011 1:12 PM
10-01-2011 11:02 PM
not getting 81 always...still getting more than 60 mb always...
far far better than what i used to get...
11-01-2011 11:32 AM
