Speed Issue PLEASE H
martyboi86
My connection speed is terrible can someone please shed some light on this for me...my router stats are
Uptime: 1 day, 0:08:10
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,164 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 64 / 128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 45.47
Output Power (Up/Down) [dBm]: 0.0 / 4.5
Line Attenuation (Up/Down) [dB]: 13.5 / 28.0
SN Margin (Up/Down) [dB]: 31.0 / 31.5
Vendor ID (Local/Remote): TMMB / P
Loss of Signal (Local/Remote): 131,073 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 131,074 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 1 / 0
HEC Errors (Up/Down): 0 / 0
martyboi86
Re: Speed Issue PLEASE H
anyone any ideas on this?Huh
Fixes: 62
It looks as though both up and downstream have been banded - I have never seen that before
A rep may be able to help tomorrow
martyboi86
Any reps available to look into this please?
Plusnet Staff
Plusnet Staff
Fixes: 159
Are you plugged into the master socket or test socket (where the line first comes in to the property)?
Remove any extension leads, sky boxes etc and plug a single filter into the master or test socket and post the router stats after that again.
 Chris Parr
 Plusnet Staff
martyboi86
The above router stats are from the master socket. The router stats are the same when plugged into the test socket behind the faceplate also. Theres no modifications to the socket either. There is nothing plugged into the socket apart from the router itself + filter.  It's definatly been "banded" for some reason. you can imagine my frustration as the speed is ridiculos. also tryed another router and its exatly the same.
Plusnet Staff
Plusnet Staff
Fixes: 159
Your line is on 20CN and therefore *not* banded as banding only applies on ADSL2+ lines. If you can use the faults checker rather than raising a normal ticket we'll be better placed and better armed with the information needed to investigate this.
http://faults.plus.net
I'm going to try an SNR reset, so give it 30 minutes before raising this as a fault please.
 Chris Parr
 Plusnet Staff
Fixes: 10
Quote from: martyboi86
Do you have any other telephone sockets? If so please bear with us and post the stats you actually get when plugged in to the test socket. Could you also confirm that when using the test socket all the extension sockets are dead.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Plusnet Staff
Plusnet Staff
Fixes: 159
Can you log in to the router and ask it to disconnect/reconnect once. Let us know once you've done this.
 Chris Parr
 Plusnet Staff
martyboi86
Ill do this later tonight. im at work.
Plusnet Staff
Plusnet Staff
Fixes: 159
In fact, don't worry about doing that, it's all looking good from here. Your sync is now 8128 and your profile has increased to 7150.
 Chris Parr
 Plusnet Staff
martyboi86
ok thanks alot chris. ill check it when im home and let you know how i get on.
