Speed Improvement?
- Speed Improvement?
Speed Improvement?
01-12-2007 5:00 PM
Re: Speed Improvement?
01-12-2007 8:11 PM
Can you post your linestats. Even though you are on a 8Mb product that does not mean you have been maxed( put on an up to 8mb connection). You may be on a fixed rate 2meg connection. If you cant find your linestats try here http://www.kitz.co.uk/adsl/frogstats.htm
Once you have posted these, we should be able to shed some light on how fast you could/should get.
02-12-2007 6:09 PM
http://img136.imageshack.us/img136/7588/11rf9.png
http://img136.imageshack.us/img136/6056/22pi7.png
http://img136.imageshack.us/img136/8963/33ep1.png
I did a speed test and got 1.3Mbps. Can someone turn off my interleaving for me?
Also, PlusNet are sending me a new Router/Modem, will that make a difference?
02-12-2007 11:39 PM
I suspect you previously synced below 2848kbps and your IP Profile is probably 2000kbps, which would lead to speed being about the value you mentioned.
Your stats show your noise margin at 4dB was below the 6dB target, and into the evening it is likely your modem might lose sync and reconnect at a lower speed to restore the noise margin.
The number of transmission errors shown in your stats seems high to me, suggesting your line is exceptionally noisy. You might find working through points mentioned in Jameseh's blog "Broadband Speed Fault Troubleshooting" helpful.
Turning off Interleaving is unlikely to improve speed, in fact it could well have the reverse effect. The new router might help a little - how do you plan to connect your computer to it (wired or wireless)? - though sorting out the cause of what seems to me to be excessive noise on your line is the priority. Is all your equipment properly filtered as described in the blog?
03-12-2007 9:24 AM
03-12-2007 9:29 AM
Yesterday, your sync speed took a blip at 1728Kbps, causing you to be assigned a profile of 1500Kbps, hence your currently "poor" speeds.
As spraxyt mentions, you're currently syncing at 3328kbps, which if maintained, should give a profile of 2500Kbps and an improvement in your throughput of roughly 800Kbps.
03-12-2007 9:37 AM
I've also put a microfilter in every socket, i currently have 1 phone and 1 modem in the sockets and when i get my wireless router im going to connect it to the master socket and try wireless on the PC, if that works ill use wireless on the Xbox 360.
03-12-2007 9:45 AM
As mentioned above, you need to wait up to 3 days for BT to increase your profile based on your sync speed.
We have no control over this, but only the profiling on our own network.
Please feel free to have a read of the speeds troubleshooting guide linked to in my signature. It might help you improve your understanding of how the Max product works. It's not the simplest!
03-12-2007 10:01 AM
03-12-2007 10:04 AM
That sounds like a pretty reasonable assumption
04-12-2007 11:58 PM
Can anyone make sense of these and tell me if they are good, bad or ok? And what changes i could make if there is any problems.
05-12-2007 10:10 AM
You don't appear to have posted your line stats, unless I'm missing something?
