Speed I'm Getting With BT Is Shocking
BigTabs
Hacked openreach modem
10 REPLIES 10
picbits
Re: Speed I'm Getting With BT Is Shocking
Didn't you have issues with your line when you were with BE ?
I remember you having a bit of a moan about speeds and service over there.
BigTabs
nope when i was with BE* it was great aka all good
Oldjim
Resting Legend
Fixes: 63
If you are with BT why are you posting here
If you are with Plusnet fibre what is your complaint - why do you think the speeds are shocking
BigTabs
I'm joining plusnet
BigTabs
I'm not with BE* or BT Now I’m Joining Plusnet !
jim:red All CAps removed as per Forum Rule mod:end
Oldjim
Resting Legend
Fixes: 63
so why is the title of this thread " Speed I'm Getting With BT Is Shocking"
BigTabs
It's when i was using them as isp im using dongle now till plusnet take over
Oldjim
Resting Legend
Fixes: 63
So why do you expect the speeds to be any different as it is the same line with the same Openreach cabinet
w23
Fixes: 4
Line stats well below 'attainable speeds' (and clearly 'rounded') suggest something similar to a 'banded profile' (as it's known on ADSL), possibly a result of an intermittent connection issue.
I also notice no errors reported on the modem's GUI, have you tried telneting and reading stats that way?
Call me 'w23'
Kelly
Fixes: 9
So, you were with BE, but you've moved to BT and are seeing poor speeds, and are currently in the process of moving to us?
If that's right, we'll do our best to get your speeds sorted!
Kelly Dorset
Ex-Broadband Service Manager
