Speed Help
Y2J
Speed Help
Hello
Yesterday after noon my router light went off just the internet light (im using a voyager 2110) and kept going off every half a hour then it stopped doing it so frequent its like once every 2 hours.
my speed when online is less than 200kbps i have not gone over my usage either.
I had sky TV installed last week but i dont think that has anything to do with it because the problem would of occured during the week.
Reply plz
Thanks.
Fixes: 62
Re: Speed Help
Despite your suggestion that the Sky installation isn't the problem.
Is the Sky box properly filtered.
I would try disconnecting the Sky box from the phone line and see if things improve
Y2J
Re: Speed Help
Yeh its connected to the filter.
I just unplugged the sky cable and there is no change.
Re: Speed Help
I've seen suggestions that some Sky boxes need double-filtering to suppress their interference with broadband adequately. If you've got a spare filter try that, but make sure your broadband is in the filter that's plugged directly into the master socket or you'll kill it.
Y2J
Re: Speed Help
I dont get it  its been fine all week not one problem, i have iused the broadban fault checker and nothing is up.
Il try the filter thing mate.
Y2J
Re: Speed Help
I have tried it with the sky line in on its own with a filter plugged into the other filter and there still no speed change.
Fixes: 62
Re: Speed Help
I am a bit confused.
I don't have Sky - so I don't know the full installation details
I assume your Sky box is connected to the dish and with a separate connection to the phone line and this is what you refer to as the Sky line.
Did the Sky installer just connect the box to an existing phone socket or wire back to the master socket.
As a last resort can you remove the lower half of the master socket and connect the modem to that. This should bypass everything in your house although I have heard of Sky installers connecting directly to the BT wires which is illegal
Y2J
Re: Speed Help
Thats what he done for me, but yesterday my speed dropped and my interlight would go off as well as my dsl light.
[Moderator's note by Peter (PJ): Please do not quote from the previous post in full, as per the link:rules]
Re: Speed Help
That definitely sounds like hte sky box adding noise to the line and causing intermittent sync.
There's a post on here where someone (might be Oldjim) has double filtered a fax machine to avoid this sort of thing and it's worked quite well - could you try putting the sky box through the phone side of another microfilter (as well as the one that's fitted) and let us know if that doesn't help?
Fixes: 62
Re: Speed Help
Yes it was me but people keep misreading my post so I will modify it.
Re: Speed Help
Apologies Jim, sorry about that  Embarrassed
I still think it's a good idea though, even if it's not a direct report of it being successful.
Fixes: 10
Re: Speed Help
Quote from: Y2J
When you said there is no change was that there was no improvement when you ran a speed test or that your sync speed reported by your router/modem did not improve?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Y2J
Re: Speed Help
My speed is still low using the two microfilters.
Fixes: 62
Re: Speed Help
Just as a check - I assumed that when you quoted speeds that these were synch speeds not speedtest results.
Can you confirm that and also quote the stats from your router (speeds, attenuation and noise margin). If you don't know how to get them have a look here http://www.kitz.co.uk/adsl/frogstats.htm
Y2J
Re: Speed Help
Im not that clued up on all this so bare with me
Here is some info from my router
Line Mode G.DMT   Line State Show Time
Latency Type Interleave   Line Up Time 00:00:02:53
Line Coding Trellis On   Line Up Count 3
Statistics Downstream Upstream
Line Rate 1856 Kbps 448 Kbps
Noise Margin 14.8 dB 18.0 dB
Line Attenuation 51.0 dB 27.0 dB
Output Power 17.7 dBm 12.1 dBm
K (number of bytes in DMT frame) 59 15
R (number of check bytes in RS code word) 16 16
S (RS code word size in DMT frame) 4 8
D (interleaver depth) 8 4
Super Frames 10173  10171
Super Frame Errors 0  0
RS Words 172956  86453
RS Correctable Errors 22  0
RS Uncorrectable Errors 0  0
HEC Errors 0  0
OCD Errors 0  0
LCD Errors 0  0
ES Errors 0  0
