Speed Help please.
- Speed Help please.
Speed Help please.
22-01-2008 9:22 PM
Hi guys, reset my router the other day and i have been having problems since with speed ect. first off i had it set to ppoe and couldnt access sites other than google, changed to ppoa and its fine, but my speed has been suffering since.
22-01-2008 21:11:30 1702.6
22-01-2008 20:40:49 968.8
21-01-2008 22:00:58 2383.4
12-01-2008 00:47:37 4835
07-01-2008 08:01:18 4956.8
07-01-2008 07:58:09 5245.7
Do i need to have it on Routed VC-MUX or Bridged? And does my VCi need to be on 38?
I have my line conencted directly into the master socket, i will try a recycle again now after posting this but i cannot think of anything else. Other than i9 am very close to monthly cap.
Many Thanks
Many Thanks
Message 1 of 5
(1,322 Views)
4 REPLIES 4
Re: Speed Help please.
22-01-2008 9:25 PM
http://www.plus.net/support/broadband/help_and_setup/connections_settings.shtml
Message 2 of 5
(456 Views)
22-01-2008 9:34 PM
Well i have the correct settings. Must be somehting else then.
Worse after restart
22-01-2008 21:35:13 1005.4
Worse after restart
Message 3 of 5
(456 Views)
23-01-2008 10:16 AM
What sort of results do you get from http://mybroadbandspeed.co.uk ?
I've had a look at your profiling and there's no apparent reason why your speeds would be poor.
Message 4 of 5
(456 Views)
23-01-2008 1:46 PM
Thanks for looking, must seems to be running fine now.
Today 13:44 5027 kbps (628kB/s) 317 kbps (39.6kB/s)
Must just be a peak time issue.
Thanks again.
Chris
Thanks again.
Chris
Message 5 of 5
(456 Views)
