Speed Fault
- Re: Speed Fault
Speed Fault
05-09-2017 1:31 AM
I have been getting a down load speed of around 1.75 Mb/s and an upload of around .7 Mb/s, this appears to have dropped to .6 Mb/s with the upload remaining around .7Mb/s.
i.e. the down load speed is less that half that of what I have been getting.
This falls short of even the Estimated speed given to me - and we are now unable to watch BBC iplayer for example.
Before making this post at 1.26 am the test was run again with a direct connection to the router with similar results.
When using the BT wholesale broadband test, and selecting run a further diagnostic it kept reporting:
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Please advise, thank you.
Paul
Telephone number: Phone exchange: CASTLEFORD Estimated line speed: 1.0Mb (This may vary between 0.75Mb and 2.5Mb) - Checked on 2017-08-22 14:26:44 Current line speed: 0.6 Mb
Re: Speed Fault
05-09-2017 10:03 AM - edited 05-09-2017 10:04 AM
Have you tried self help via links below?
Plugging router into test socket of the BT Master socket would eliminate any internal wiring issues.
Re: Speed Fault
05-09-2017 10:06 AM
Yes have eliminated internal wiring, have tried the other links except for chat service which is not operational - will keep trying.
Thank you for your response.
Paul
Re: Speed Fault
05-09-2017 10:10 AM
CHAT's suspension is allegedly to put more staff onto the phones ie to reduce waiting times.
Hmmm.
Re: Speed Fault
05-09-2017 1:05 PM
Re: Speed Fault
05-09-2017 1:15 PM
Thank you very much for getting back to me on this.
I have also had a response via private message on FB, so will respond there.
Thank you again - much appreciated - Paul
Re: Speed Fault
05-09-2017 1:22 PM
