Speed Fault
- Re: Speed Fault
Speed Fault
16-06-2014 11:20 AM
Hello
I've experienced some pretty awful speeds on my line.
Here's my noise test:
http://puu.sh/9vRiB/f968555759.png
My BT line profile test:
http://puu.sh/9vRsl/2bc20a1f5e.png
Current Line Speed from Plusnet:
http://puu.sh/9vRuN/b9f7d7208f.png
Using the test socket, my BT line profile test is identical:
http://puu.sh/9vS2b/b8c425dbe5.png
I tried doing a wholesale test via BT however I experience an error midway through and it fails.
I would usually expect speeds of up to 200kbps. I'd really appreciate your assistance here.
Thanks for your time.
Message 1 of 3
(448 Views)
2 REPLIES 2
Re: Speed Fault
16-06-2014 11:28 AM
The bad news is that because you are on a 20CN exchange your IP profile will take a day or so to recover
It looks as though your default noise margin has increased to 12dB
I suggest raising a speed fault as https://faults.plus.net
Message 2 of 3
(291 Views)
Re: Speed Fault
16-06-2014 3:04 PM
Hi Adam,
Sorry to hear about this, it's happened as you're connection is dropping fairly frequently:
Going to advise reporting a fault over at http://faults.plus.net
<img src="http://community.plus.net/visualradius/generated/image14029273951543.png"/>
Message 3 of 3
(291 Views)
