Speed Dropping Again
- Speed Dropping Again
19-07-2013 11:30 AM
Re: Speed Dropping Again
19-07-2013 12:23 PM
Have you power cycled your modem?
I've also noticed that you've had a few drops recently, have these been initiated by yourself?
<img src="http://community.plus.net/visualradius/generated/image137423289814.png"/>
19-07-2013 12:51 PM
19-07-2013 1:29 PM
22-07-2013 5:32 PM
Detailed Records
Attribute: DownStream-BE UpStream-BE
TAP ID: TAP-1 TAP-1
Test ID: 1374229462 1374229463
Start Date/Time: 19-07-2013 11:23:21 19-07-2013 11:23:34
Profile Rate: 58273 20000
Test File Size: 86873160 488927
File Transfer Average Throughput/Session: 56500 6060
Available Products RAG Exchange Status Reason Code Capacity Date Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Line Range in Mbps
WBC FTTC Green Enabled A - Up to 54.8 Up to 13.2 -
In sync but no connection, possible router issue for that side of things. With regards to the speed issue, the circuit is only estimated to run at 54.8mb so there is no fault despite historic speed tests.
My speed tests show a downward change
..7/19/2013 4:13 PM GMT 87.114.138.144 51.10 Mb/s 8.91 Mb/s 10 ms Milton Keynes 50 mi
7/19/2013 4:12 PM GMT 87.114.138.144 57.02 Mb/s 8.83 Mb/s 23 ms London < 50 mi
7/19/2013 10:26 AM GMT 31.185.194.82 56.27 Mb/s 9.51 Mb/s 23 ms Ealing < 50 mi
7/14/2013 8:20 AM GMT 91.125.201.34 65.49 Mb/s 17.58 Mb/s 7 ms Ealing < 50 mi
7/11/2013 9:50 PM GMT 91.125.201.34 65.73 Mb/s 17.69 Mb/s 7 ms Ealing < 50 mi
7/10/2013 10:07 PM GMT 87.114.207.141 65.85 Mb/s 17.16 Mb/s 7 ms Ealing < 50 mi
7/8/2013 10:12 AM GMT 46.208.3.67 75.60 Mb/s 14.99 Mb/s 16 ms Newbury ~ 50 mi
7/7/2013 10:09 AM GMT 46.208.3.67 70.01 Mb/s 16.54 Mb/s 7 ms Ealing < 50 mi
7/5/2013 10:37 PM GMT 91.125.251.206 71.10 Mb/s 16.61 Mb/s 6 ms Ealing < 50 mi
7/1/2013 12:52 PM GMT 80.229.116.237 72.59 Mb/s 17.41 Mb/s 6 ms Ealing < 50 mi
7/1/2013 6:53 AM GMT 80.229.116.237 72.56 Mb/s 17.35 Mb/s 6 ms Ealing < 50 mi
6/30/2013 6:48 PM GMT 80.229.116.237 72.43 Mb/s 17.38 Mb/s 6 ms Ealing < 50 mi
6/28/2013 10:24 PM GMT 80.229.116.237 72.34 Mb/s 16.99 Mb/s 7 ms Ealing < 50 mi
Any help would be good, thanks...
23-07-2013 9:30 AM
It's unlikely given your speed estimate of 54Mb that we could get a fault raised on that basis, however if the line is dropping connection (which it looks like it might be) we could certainly get that sorted out - it could be that causing the profile to drop, so you might get the speed back if the drops can be fixed (assuming they're happening).
It might well be worth a chat with the faults team, if you send the ticket back to them with your comments they'll be able to check up on it and should call to discuss the issues as was attempted yesterday afternoon.
25-07-2013 12:58 AM
Just a bit disappointed after a constant 78mb sync, the cabinet is only 150 yards down the road and i am close to the exchange, something has certainly been changed..
25-07-2013 1:22 PM
I'd be interested to hear how things go for you with this problem.
25-07-2013 2:32 PM
@zackarydoo - I'm afraid the notes from the engineer visit are not yet available, though we'll keep checking for you and update you when we know more.
25-07-2013 7:24 PM
I can sense from the other posts that I am not the only one frustrated by a drop in performance, it just seems like the more customers on the line the smaller the bandwidth they achieve, my line can take 78mb easily it just seems like its been stuck low to help others, please correct me if i am wrong, I have been into the fastest available broadband and now Fibre for the last 10 to 15 years and i have experienced the rough with the smooth. Previously I was with BeUnlimited and always had a steady 22mb from a 24mb line which was the best from a non Fibre line.
If there is a fault on the line so be it, but from other peoples posts it just seems too many customers = traffic shaping and throttling the line.
Thanks Mike.
26-07-2013 11:47 AM
Our team will get back to you regarding the fault as soon as they can.
28-07-2013 11:38 AM
My connection has dropped a few times is there anything else that could be done ?
My Latency has gone from 6ms to 23ms something has happened, i just can't work out why my line speed would suddenly drop from 78Mb to 58Mb, if it had always been 58Mb I would have been none the wiser.
Any help would be appreciated.
28-07-2013 4:10 PM
28-07-2013 4:37 PM
29-07-2013 2:52 PM
On my previous Broadband line with BeUnlimited they reduced my SNRM to the lowest setting of 3dB and the line was very stable with no dropouts.
If DLM has set my line speed low can you do a manual reset, i would guess this would also set a low Interleaving as well ?
The Cabinet is only a 100 Yrds from my house so there should be no issue with that part..
