Speed Dropped!
Joopzor
Speed Dropped!
Speed has been fine for ages and today i cant download any faster than 20Mbps - been on 77Mbps for about 2 weeks
Here is a speedtest Today
This was few days ago
Re: Speed Dropped!
I've had a quick look over your conenction and nothing seems to have changed in the last few days. Are you connecting wired or wireless?
Joopzor
Re: Speed Dropped!
Hi it turns out to be a Laptop charger causing my homeplugs to sync stupidly slow!
New result
I think the speedtest + thinkbroasband servers could be overloaded as usenet is reporting 76Mbps download
Sorry to waste your time like this.
Fixes: 5
Re: Speed Dropped!
Can you do a http://speedtest.btwholesale.com/ at peak tonight just in case?
Kelly Dorset
Broadband Service Manager
Fixes: 20
Re: Speed Dropped!
I just had to switch gateways tonight.
On (forgot to save the g/w was something 01)
I got
Now getting
on ptn-ag02
No changes just a drop/connect
EDIT: no streaming radio on this g/w moving again
Fixes: 5
Re: Speed Dropped!
no streaming?  What to you mean by that?  It won't start?  Starts but buffers?
Kelly Dorset
Fixes: 20
Re: Speed Dropped!
No sound, streaming radio.
Just jumped to ptw-ag04
BUT
But I do have radio again.
Fixes: 20
Re: Speed Dropped!
Jumped to ptw-ag03
Radio ok but no speedcheck Huh Hung on ping test
Fixes: 20
Re: Speed Dropped!
Sorry for hijacking you thread mate.
Latest on pcl-ag01
Radio ok
Streaming radio is via a small applet, I have it on all day so notice when it doesn't work (currently streaming @15K ish)
Fixes: 20
Re: Speed Dropped!
Ok found one I like  Cheesy
ptw-ag02
Radio playing happily as well.
Joopzor
Re: Speed Dropped!
all looks good for me iam on AG08
Joopzor
Re: Speed Dropped!
Just to add
BT checker
Download speed (Mbps): 68,58
Upload Speed (Mbps): 14.92
Ping (ms): 24.00
Joopzor
Re: Speed Dropped!
Update 8:30
[Censored] is going on plusnet how can i game like this
djamelh
Re: Speed Dropped!
Getting massive latency. 185-215ms to bbc.co.uk and various other sites.
Connecting to work VPN is painful, and cannot stream from youtube (buffers for a few seconds, then struggles to keep up, and getting constant stuttering as it buffers).
This has been on for a while, any ideas when it will be resolved? Day time it works fine.
Joopzor
Re: Speed Dropped!
disconnected n got to another plus.net server! ag04 seems good
