Speed Dropped since 08/05
- Speed Dropped since 08/05
Re: Speed Dropped since 08/05
14-05-2013 1:45 PM
Before we arrange an engineer visit, two small points/queries...
- I don't have an obvious master/test socket so I've not been able to definitively test this but I have tried the router at all 3 points.
- The issue doesn't seem to be constant so I'm worried about the possibility of being charged for an engineer visit that shows "no problems" but is followed that evening during the "peak" hours with the low speeds... any thoughts?
14-05-2013 2:42 PM
14-05-2013 2:58 PM
14-05-2013 3:45 PM
14-05-2013 4:01 PM
14-05-2013 4:13 PM
14-05-2013 4:18 PM
So I can let the building caretakers know about the expected visit, can you confirm this is a BT Openreach engineer?
14-05-2013 4:49 PM
16-05-2013 11:20 AM
16-05-2013 12:42 PM
17-05-2013 9:08 PM
He suggested trying an alterative router as a possible solution since we know everything up until it reaches the router is fine with his test equipment. I've tried this tonight after laying my hands on one from my family but this produced the same end results.
Where do we go next...?
18-05-2013 10:18 AM
Router DSL Connection Link Information
Uptime: 0 days, 15:12:35
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 444 / 17.679
Data Transferred (Sent/Received) [MB/GB]: 202,15 / 1,99
Output Power (Up/Down) [dBm]: 12,4 / 0,0
Line Attenuation (Up/Down) [dB]: 8,8 / 19,0
SN Margin (Up/Down) [dB]: 30,4 / 6,0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 29 / 0
FEC Errors (Up/Down): 0 / 48.354
CRC Errors (Up/Down): 0 / 38
HEC Errors (Up/Down): 0 / 424
Downstream sync speed now at the 17Mbps the Openreach engineer showed me the line as reaching on his testing device.
Saturday afternoon approaches...
Sunday morning brings something a bit better...
20-05-2013 10:27 AM
20-05-2013 10:37 AM
There are also obvious differences in performance when using video streaming apps on Xbox (for example Sky Go on Xbox on 'auto' setting doesn't reach the same picture quality as previously) and a Samsung Smart TV (where BBC iPlayer streaming is regularly buffering and channels delivered via Connect TV are stuttering).
20-05-2013 10:54 AM
