Speed Dropped 50%
- Speed Dropped 50%
Speed Dropped 50%
29-01-2012 10:05 AM
I've got the pro addon and it doesn't matter what time of the day I check the speed is always the same. I've tried rebooting both modem and router with no joy.
Any ideas?
Re: Speed Dropped 50%
29-01-2012 10:54 AM
Quote from: michellereid My download speed via the bt speedtester was 14MB.
Was this done over wireless or ethernet?
29-01-2012 11:29 AM
29-01-2012 11:49 AM
If you want to rule out the router and have a spare half hour then you could try going direct to the modem using the instructions here.
29-01-2012 12:17 PM
Also i've noticed that the speed when downloading isn't constant like it used to be. For example I tried downloading a linux ISO and instead of downloading at a steady 2.5-4Mb/sec - it gets to say 1.5Mb/sec then drops to 900Kb/sec then slowly gains speed a bit then drops. No matter what I download and what ever server i'm downloading from the speed isn't constant.
29-01-2012 12:58 PM
I plugged the laptop into the lan1 port of the modem, followed the instructions and created a new connection. I did a speed test via speedtester.bt.com and the download speed was 34MB. Downloading a test file nearly hit the 5Mb/sec mark steadying out at around 4Mb. I did a speed test via speedtest.net and download was 34.6MB upload 1.6MB...
I swapped back to the router and the same speed test gave me 19MB download.
Plugged into the modem:
Plugged into the router:
29-01-2012 1:54 PM
Quote from: michellereid Right the problem does seem to be the router.
I'm assuming it's the standard WNR1000v3 that PN supply? If so then I'd wait until tomorrow and see what the Digi Care team say.
Alex
30-01-2012 6:34 PM
What would course the router to slow the connection by that much?
31-01-2012 1:48 PM
I can arrange for a replacement, but before I do can I just confirm that you have tried..
Switching the router off and on
Using a different ethernet port/cable
Factory reset of the router
Jojo
31-01-2012 6:38 PM
I've tryed all ports and used a different cable. I've not done a factory reset though. But i've just ordered myself a new router from amazon a few hours ago
TP-Link TL-WR1043ND Ultimate Wireless N Gigabit Router
http://www.amazon.co.uk/gp/product/B002YETVTQ
dick:quote
