Speed Drop
dennisb66
Speed Drop
Have just discovered that my d/l speed is less than half of normal.I have made no changes. Bt speed test is...
Download speed achieved during the test was - 665 Kbps
For your connection, the acceptable range of speeds is 200-1000 Kbps.
Additional Information:
Your DSL Connection Rate :928 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 750 Kbps
Previous Plusnet test on 4th May.....
Please check this out for me.
thank you
Dennis
[Moderator's note by Dick(Strat) All caps title edited as per forum rules.
[color=green]...and image tags fixed.
Fixes: 47
Re: Speed Drop
I've just checked your account and can't see anything obvious.
Can you log a fault here please https://portal.plus.net/apps/kbdfaults
Our faults team will then be able to help you dig deeper into this one....
 Adam Walker
jojopillo
Re: Speed Drop
HI dennisb66,
How is your kit set up? Are you in the test socket? Using extension cables/sockets? Your SNR is really high so something has caused that, and ultimately this will have dropped your speed. If we can find out what may have caused the noise then maybe we can do something about it.
Jojo Smiley
dennisb66
Re: Speed Drop
Hi Joanne,
  Yes I am in the test socket,no extension cables.Faults dept.mentioned a disconnection about 2 weeks ago,have no idea what caused it,everything is the same as always so don't know how i can help. Had same problem a few months back which you resolved Jo.  Time to wave your magic wand.lol
Dennis
jojopillo
Re: Speed Drop
Hi Dennis,
Looks like a stuck profile, give me a nudge in the morning and I'll get onto BT about it.
Jojo Smiley
dennisb66
Re: Speed Drop
Cheers Jojo,
dennisb66
Re: Speed Drop
Good morning Jojo,
                      Here's your nudge for today lol Grin
jojopillo
Re: Speed Drop
Thanks Dennis, I'll get onto that now. Smiley
jojopillo
Re: Speed Drop
Hi Dennis,
That's done now. Your profile is 2500 which you should see in the next 15 minutes.
Jojo Smiley
dennisb66
Re: Speed Drop
Take a bow Jojo Grin  all is back to normal,many thanks Kiss Kiss
Download speed achieved during the test was - 2159 Kbps
Your DSL Connection Rate :2976 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
Dennis
jojopillo
Re: Speed Drop
Great , thanks for letting me know. Smiley
