Speed Drop
FIXED- Subscribe to RSS Feed
- Speed Drop
09-01-2017 10:07 PM
My broadband speed has slowed right down. Called support today who did some checks and said there was an issue and told me to wait 4 hours then switch modem off/on.. I did this, but the speed seems about the same.. Pages start to load then take ages to finish loading and sometimes fail.. My router (thomsom) is the one supplied when i first signed up 6 yrs ago.. Could it be getting tired and need replacing or do they either work or not work? Have very little tech knowledge abt this. Have managed to login to the router and do a test which says everything is working (green ticks).
Any advise very welcome!
Clay
Fixed! Go to the fix.
Re: Speed Drop
10-01-2017 12:09 PM
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 13 | 23.5 |
SNR Margin: | 31 | 17.5 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | 0 |
Cell Count: | 5034 | 19303 |
Speed: | 448 | 8128 |
Maximum Stable Rate (KBPS): | 8128 | Fault Threshold Rate (KBPS): | 6502 |
Mean Time Between Retrains (Seconds): | 6156 | Mean Time Between Errors Upstream (Seconds): | 474 |
Indicative Line Quality: | S | Mean Time Between Errors Downstream (Seconds): | 15 |
Re: Speed Drop
on 10-01-2017 12:21 PM - last edited on 10-01-2017 2:09 PM by Strat
Hi Chris, Thanks for this speedy reply... I'm not so technical so some of the data is lost on me.. I did an online chat this morning with [CSA Removed] and he's do a reset i believe and told me to switch modem off/on in 4 hours if situation doesn't improve.. I think it is slightly better but not what i've been used to.. I need to get back to full speed if i can (i'm wondering about switching to fibre, but that's for another discussion)..
What is the source of the line error every 15 seconds? I'm guessing this is at the root of the problem.. Is your advice the same as [CSA Removed] now... Monitor for the next few hours then reboot modem?? I don't want to make any more errors and put things back further..
Cheers for the help.
Very much appreciated.
Clay
Moderator's note by Dick (Strat) CSA name removed as per Forum rules
Re: Speed Drop
11-01-2017 12:44 PM
That's what we need to find!
A single reboot shouldn't cause any problems, it's only when it happens regularly that you may encounter issues.
How's the line performing today?
Re: Speed Drop
11-01-2017 4:00 PM
Hi Chris, Thanks for your reply.. So glad of this forum! No difference in speed. Still incredibly slow.. I've raised a fault via support and i think an engineer might be coming out. They say i might have to pay, but i'm willing to take the risk. The guys you speak to when you ring have tired a reset twice now, then i wait 4 hours and reboot modem, but it has no affect.. I'm wondering about my modem as it's 6 years old, but haven't got the knowledge to change it.. Or could it be in the cabinet down the road?? I've know idea... I just know i miss having connectivity!!! If you can help i'd be REALLY grateful..
In the meantime i will just have to be patient.. Doesn't come natural i can tell you
Thanks Chris
Re: Speed Drop
11-01-2017 9:25 PM
Chris, Just been re-reading your reply.. You said:
"Your line was disconnecting quite frequently, this in turn caused the exchange equipment to make changes to the line to try and stabilise it with the side effect of causing the speed to slow down." ...
Does this mean the problem i have is at an exchange somewhere and not with my equipment? If so, any idea how long these types of faults take to fix? Does an engineer have to physically do something at the exchange? Also, is an exchange a building like the old days or a box in the road? Might as well learn some stuff while i'm not able to stream anything..
Thanks,
Clay
Re: Speed Drop
12-01-2017 1:17 PM
A fault could be anywhere along the line, back to the exchange.
The issue at the moment isn't a fault, the DLM (Dynamic Line Management) is working as intended. It becomes a fault if the speeds don't increase again.
At the moment no.
Generally they are buildings, yes.
Re: Speed Drop
12-01-2017 1:19 PM
Can you try a disconnect/reconnect for me in around 2 hours (just one) and see what the speeds are looking like please.
Re: Speed Drop
12-01-2017 1:25 PM
Hi Chris, Yes will do.. I will reboot at 3pm then unless i hear back.. The speed hasn't increased since i raised the fault. Still working at dead slow .. Things like gmail won't load apart from in basic mode... Cheers..
Re: Speed Drop
12-01-2017 3:21 PM
Hi Chris, Reboot just done (1`5:15).. Won't surf anything till it's settled down.. Fingers crossed!!
Re: Speed Drop
12-01-2017 3:53 PM
Hi Chris.. Sorry to say no noticeable difference.. If anything a wee bit slower.. All lights on modem ON and flashing away like crazy.. Does this mean what's been tried hasn't worked? Can you let me know where we go from here? Thanks for all you do!
Clay
Re: Speed Drop
12-01-2017 8:39 PM
Hi Chris. I took a small film of the modem lights to show you..
https://www.instagram.com/p/BPLXlHMlzpl/?taken-by=organicfarmshop&hl=en
It took 20 mins to load onto instagram. If anything since the reboot at 3pm the connection has got slower.. I tried to upload here but this editor wouldn't accept the file format (.MOV).. Hope it's of some use to you and this can get sorted soon.. 5 days now without proper internet..
Clay
Re: Speed Drop
13-01-2017 10:16 AM
Hi Chris, Some improvement this morning.. Whatever you did it seems to have worked!! Can't tell you how good it feels!! Thanks mate!!
13-01-2017 2:04 PM
Phew, I was getting a little worried
I'm just going to run a quick line test to see what it looks like now.
Re: Speed Drop
13-01-2017 2:05 PM
In fact, no need! I can see one of my colleagues from the faults team has already done this and spoken to you.
