Spam and Default Addresses
- Spam and Default Addresses
19-08-2007 12:33 PM
I am trying to sort out my spam problem and would appreciate a little advice. Firstly let me explain my setup and how I have dealt with spam in the past.
I don’t use server side spam filters as I don’t trust them. I have had important mail go missing this way. I normally let my local email client put suspect emails in a junk mail folder and I take a quick peek to see if there are any false positives in there.
I have never used my plusnet email address as an outgoing email address. For many years I have had domains such as www.myname.org.uk ; and used that as an outgoing email address and redirection of incoming mail to my plusnet address.
I am now receiving spam on my unused default plusnet address; presumably this is because of the security problem a while back. It’s coming in at a higher rate than I am used to and it is getting on my nerves, thus deciding to sort it out.
I have taken up the plusnet free domain option and plan to redirect all incoming emails from www.myname.org.uk to an address at www.myfreedomain.co.uk.
If I create incomingmail@myfreedomain.co.uk and set this as my default address (notifying plusnet so I still get account emails – they are the only people who use my default address) what will happen to spam aimed at my old default address, will this end up being redirected to my new default address or die a horrible spammy death somewhere else ?
Cheers
Re: Spam and Default Addresses
19-08-2007 12:37 PM
One thing PN can do, if you raise a ticket, is switch off email to @username.plus.com so that you only receive mail to your domain.
That could be handy for you?
19-08-2007 1:32 PM
Thanks for that.
It looks like turning off the default catch all and redircting mail from my external domains to newmailbox@username.plus.net would fix the problem without having to use either the new internal domain or raising a ticket.
I think I will give that a go
20-08-2007 1:22 AM
Firstly, go into your mail settings and change the name of your default mailbox. For newer Plusnet members, the mailbox will be named firstname@username.plus.com, if you've been a member for a longer time, the default will be username@username.plus.com, change it to something else. Personally, I wouldn't give it the name of something you are likely to use as an email address, just in case there is a repeat of the webmail incident, although it is unlikely - so call it mail@... or default@...
You might want to leave it at that for a couple of hours, so that it all gets set up.
Next and this is the key to solving the problem, go back into your email settings and set up a redirect for what WAS your default mailbox, whether it was firstname@.... or username@....., and use the button that tells the system to send it to the blackhole address. This will blackhole ONLY the mail addressed to what was the default mailbox.
Now you should be able to safely turn your catch all address back on, and the spam filtering off. If your spam problem is a direct result of the webmail incident AND you don't normally use webmail the only address compromised was your default mailbox, which you've now blackholed.
Hope that helps
20-08-2007 9:44 AM
I seem to be Spam free again
I had already changed my default address to mail@ (great minds think alike etc) and turned off catch all. So, no more incoming from the compromised address as they are being bounced.
I didn’t know the blackhole option existed as I haven’t ever used redirects on plusnet. I have followed your suggestions and have now enabled catch all again for the new default address.
Thanks for that.
Moot Point: bouncing and blackholing which is best for an individual and the net?
Bouncing – I suppose that if spammers continuously get bounces from an address it might eventually get removed from their list, or does the bounce just prove the domain exists and ensures it continues to be targeted?
Blackholeing – If you blackhole a spam message the sender has no idea that you have not received it and your address continues to be live therefore adding to the % of spam still flooding the net each day?
As an example, about 2 years ago a customised address on one of my external domains was compromised, the address had in fact either been hacked from the database of a major company (or sold on by a rouge employee). I started to receive a torrent of spam, more than I could possibly live with. At the time my solution was to set up a googlemail account and redirect mail from the compromised address there. That address regularly received over 3,500 spam messages a month; even now it still receives about 1000 a month. The compromised address has therefore been subjected to between 50,000 to 100,000 mails and is still going strong. Frightening isn’t it?
20-08-2007 10:25 AM
20-08-2007 10:40 AM
anythingyoufancy@username.plus.com you can then make it catch all or not.
20-08-2007 3:33 PM
20-08-2007 4:22 PM
The benefit of this process (apart from the lack of spam) is that you don't need to change your username or switch the catchall off. I'm sure that spammers will eventually find another way of spamming me but in the meantime I have minimum disruption and when spam returns I'll deal with it in a similar way.
20-08-2007 5:21 PM
20-08-2007 6:01 PM
You shouldn't have to pay for a domain name if you're yet to accept our offer of a free one. The offer ends today, so you'd have to be quick but you should be able to register one here.
20-08-2007 7:31 PM
20-08-2007 11:48 PM
Quote from: God Moot Point: bouncing and blackholing which is best for an individual and the net?
IMHO, bouncing is a no-no. It generates unnecessary net traffic and the chances are that the spammer forged the 'From' address. Then some poor soul is wondering why he/she is suddenly getting so many bounced mails that were never sent anyway. Just my opinion of course.
Glad to see you're back to a spam free situation.
21-08-2007 8:10 AM
