Sorry, speed grumble..... again
Really slow here this morning, These speeds are useless to me.
What's happening out there?
sophos9
Re: Sorry, speed grumble..... again
Whats your BT IP Profile?
speedtester.bt.com
James
That's not good.
Do you see any improvement following on from a reboot?
This is the BT IP profile from the speedtester
Test1 comprises of Best Effort Test:  -provides background information.
    IP profile for your line is - 2500 kbps
    DSL connection rate: 448 kbps(UP-STREAM)  3584 kbps(DOWN-STREAM)
    Actual IP throughput achieved during the test was - 2333 kbps
I just ran the speedtest again and got this. which is typical of what I normally get
Bit different from the last test half an hour ago Huh
Edit 1
The difference on the graph is amazing (sorry but  I don't know how to put it on here)
Edit 2
I have not rebooted the router yet
