Sorry – please can I request another SNR reset on our line.
- Sorry – please can I request another SNR reset on ...
Re: Sorry – please can I request another SNR reset on our line.
06-10-2012 8:54 AM
06-10-2012 9:44 AM
06-10-2012 11:23 AM
The SNR reset doesn't appear to have taken place at this end.
I've just checked the router stats - no re-sync has taken place here following the SNR reset. It's been up for 33.5 hours since last reconnected. Syncing at 12118kbps with a Moise Margin of 11.5dB still.
Any thoughts?
06-10-2012 11:42 AM
06-10-2012 11:49 AM
If it can be set lower that is what I'm after as I believe that the line is nice and solid.
Will it be another 10 days before another reset can be carried out though?
06-10-2012 12:12 PM
06-10-2012 12:15 PM
Thanks ever so much!
06-10-2012 12:44 PM
06-10-2012 4:05 PM
07-10-2012 8:48 AM
It’s Sunday! Or should that be Snrday!
Hopefully any stabalisation period has now finally ended. As mentioned yesterday, please can you put through another SNR request today with a target of 6db?
With many thanks for your help, support and patience. Hopefully we’re just about there now!
BTW, looking at another related post someone made last night, I should have copyrighted my opening post!
07-10-2012 10:37 AM
I have initiated the SNR Reset with a target of 6db for you. This should bring your sync level up back to normal. This can take around 4 hours to take effect. Let me know if there is anythign else I can do to help
P.S - I think we should be about there now
07-10-2012 11:35 AM
Download back to 16164kbps with Noise Margin of 6.0db! Does anything need doing with your line speed information as it's still showing 10.6Mb (BT profile currently up to 14.26 Mbps).
However...
The upstream has now been capped at 440kbps (NM 28.0db)
Can this be uncapped please and then we're home and dry!
Thanks for all your help!
07-10-2012 12:14 PM
I've changed the Speed Profile for you, you'll just need to restart your router for this to take effect.
By moving your target SNR down to 6db, it has uncovered a fairly large number of errors on the line which concerns me a little. We'll see how you go over the next 10 days anyway.
I can uncap your upload speeds but this can't be done until the training period has completed, but I'll make sure I do it for you. I hope that's not a problem
07-10-2012 12:30 PM
I've no problem waiting for uncapping of uploads at all!
Regarding the errors, like you say we'll see what happens over the next ten days and go from there. Nothing will be fiddled with from this end so there should get a 'true' picture of the line at last!
07-10-2012 12:35 PM
Excellent, if there is anything else I can do, just let me know.
