Sorry.....But I am sick to death with the problems on my line.
- Sorry.....But I am sick to death with the problems...
Re: Sorry.....But I am sick to death with the problems on my line.
29-12-2012 6:05 PM
I have started it up again though and for the last couple of days SNRM seems quite content at 6dB +/- 0.1 ups n downs
Alex
29-12-2012 6:13 PM
I'm asking because of the 3dB margin question, if yours is that stable over 24 hours.
29-12-2012 7:48 PM
29-12-2012 10:14 PM
I read the first two pages before joining in, then checked near the end as it was going nowhere in those two pages. As it seemed here to have been almost resolved by some action or other, I thought a fresh start seemed worthwhile. On the assumption that no previous tests were relevant, as the main issue had been solved. We were now just interested in the possibility and viability of 3dB noise margin. Maybe I have it wrong :).
As for reading 12 pages starting in October to find out what ADSLx variant he is on ... :-X.
29-12-2012 10:40 PM
30-12-2012 1:29 AM
There is no evidence it's been resolved. Alex's line has never been able to cope with a 3dB Target since moving onto 21CN, it struggled previously with 6dB on 20CN. Alex has made it quite clear he hasn't been monitoring of late, and in the last few days the problems has not reared it's ugly head, that is nothing unusual, and is no proof the problem has gone away. His line has been deliberately profiled on ADSL1 on 21CN with a 6dB Margin as this has been giving him a more stable connection than he's previously had.
@RR
There you go jumping to incorrect conclusions again. There have been no "recent" improvements, the Target SNRM has been at 6db for some considerable time, apart from a brief period towards the end of November when it went to 12dB after a spate of power cuts. It is also evident from Alex's post that although there was a reasonably lengthy period with no loss of sync, that doesn't mean the problem has gone away - Alex hasn't been monitoring - it just didn't cause loss of sync - but now there has been a recent loss of sync.
Alex has told us that his neighbour's line is performing much better than his, which is why I've asked if he can get the full stats to compare. We need to try and discovered what is different with his neighbours line and why it doesn't seem to be affected by the same problem. That would then give us something specific to get PN to persuade OR to look at.
30-12-2012 10:34 AM
Plusnet can tell what the target SNR for your line is from information in the reports they receive. You or I as clients do not know this; we have to infer it or ask Plusnet. Alex7127 reported 25 days of stability at a 9dB SNR. I Inferred that that was the target value at that time and now it seems to have dropped to 6 dB. I might be right about this, I might be wrong, only Plusnet might know for sure. Alex7127 has a neighbour with, it appears, a 3dB target noise margin. This is a "reward" from the DLM for a line that it considers particularly stable. So it's a reasonable inference, but not a certainty, that the neighbour never suffered from the "noise events" that caused problems for Alex7127. That's got to be a clue. But maybe, hopefully, those "noise events" have ceased. In fact for ADSL2+(21CN) "couple of days at 6dB +/- 0.1 ups n downs" seems remarkably stable.
30-12-2012 11:25 AM
Considering you have posted in this thread before on a number of occasions, you have obviously forgotten about the periodic randomness of the behaviour of Alex's line and have clearly not bothered to re-read it to refresh your memory. Hence your conclusions are wong.
The 25 days without loss of sync was at 6dB Target Noise Margin. Read what Alex has posted.
And I repeat that does not prove the problem has gone away, mearly that it hasn't caused loss of sync as on many previous occasions.
Your continued posting in this manner is disruptive and extremely unhelpful to Alex in particular.
Alex is not a technical person and has done extremely welll to cope with the difficulties of this problem for some considerable time. I think you should show more consideration before posting statements that are not correct and aren't helpful to Alex's situation.
30-12-2012 11:34 AM
KR's
Alex
30-12-2012 11:40 AM
30-12-2012 11:45 AM
He did tell me the model....but I did not write it down.......it went in then........ got lost in the grey matter I will ask him again. But he did Google it whilst I was there and it was sub £30 I know that. I am willing to buy one for that money to give it a try!
Alex
30-12-2012 1:04 PM
Now it could be that if he's less technical than you , he may not know how to get them all. So if you post the full model number and version (the latter is also important), someone will now exactly how to get to them :).
30-12-2012 3:39 PM
Given the two speeds it looks like a high attenuation, (63dB+)?), and ADSL2+ would almost certainly be the worst option of the three available protocols. ADSL2 might give 50-100kbps more, but with higher error rates that might be counter-productive re stability and throughput.
IIRC the drop wire was replaced recently, and has helped a lot. Nothing in the tread before that is really relevant to what follows it.
30-12-2012 11:03 PM
31-12-2012 9:28 AM
Alex7127, part (or perhaps all) of the reason your neighbour gets a better speed than you must be because his target noise margin is 3dB whilst yours is 6dB (as best we can tell). On a Netgear router you need to select Router Status then the Show Statistics button at the bottom of the page for more details to compare with your own. But a 3dB target noise margin would almost certainly not be sustainable whilst experiencing the "noise events" you were reporting in November.
