Sometimes losing control of character in League of Legends
Richard_MF
For about the last week I've found myself unable to control my character in LoL on occasions. I see that the game has recognised that I have right-clicked and used abilities, but it's as though it takes a while for the request to be sent and return. All of the actions I performed during the issue happen after I regain control a few seconds after. When this happens I don't see a change in ping and just happens out of nowhere.
I contacted League of Legends player support and they suggested that I enable DMZ and port forward but it hasn't solved the issue. I later performed a factory reset on the router (hub zero) and enabled DMZ and port forwarded, also to no avail. I haven't had this issue before and no changes have been made that could have caused this to happen as far as I know. When I performed a traceroute, there are timeouts from the 9th hop, although I don't know if it was this way before the problem started as I hadn't used a traceroute on the League servers before.
Tracing route to 185.40.65.1 over a maximum of 30 hops
1 <1 ms 1 ms <1 ms dsldevice.lan [192.168.1.254]
2 7 ms 6 ms 7 ms 172.17.0.107
3 7 ms 7 ms 7 ms 172.17.3.142
4 11 ms 11 ms 11 ms 172.17.10.134
5 12 ms 11 ms 12 ms be2.psb-ir01.plus.net [195.166.129.180]
6 12 ms 11 ms 12 ms 195.99.125.134
7 12 ms 11 ms 11 ms 213.121.193.207
8 11 ms 10 ms 11 ms 166-49-211-230.eu.bt.net [166.49.211.230]
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
Any help will be appreciated, thanks
silkysean
Re: Sometimes losing control of character in League of Legends
Sounds like you're having the same issues as other gamers on here at the moment with packet loss. PlusNet have still to acknowledge the issue, let alone fix it!
Moolapie
I'm also still having this issue
Richard_MF
I wasn't aware others were having the same problem, hopefully it gets sorted soon.
Moolapie
It's worse tonight than it has been in the past for me.
