Something wrong
- Something wrong
Re: Something wrong
04-01-2015 3:11 PM
Re: Something wrong
05-01-2015 9:46 AM
Re: Something wrong
05-01-2015 12:01 PM
The broadband is still at a DS noise margin of 9.5dB, it has always previously been a long term steady 6dB. Is there anything that can be done about this?
Re: Something wrong
05-01-2015 12:03 PM
Re: Something wrong
05-01-2015 12:17 PM
Re: Something wrong
05-01-2015 12:24 PM
The target SNR was actually 6db already, so I was a little suspicious of why it was currently at 9.5db. It turns out your line had been banded to ensure stability, you were syncing at the top end of the band and therefore the increased SNR was expected. I've requested the banding get removed which should happen in the next hour or so.
Re: Something wrong
05-01-2015 12:28 PM
Re: Something wrong
05-01-2015 12:38 PM
What would have caused the banding?
Re: Something wrong
05-01-2015 1:13 PM
Re: Something wrong
27-02-2015 1:19 AM
Re: Something wrong
02-03-2015 7:07 PM
Slightly faster today. I have been trying to disconnect broadband via the router before I turn power off at night.
Here are stats. I wondered if the FEC seemed rather high.
[tt]Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 11:12:15
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 0
Bearers generic info DS US
Payload rate [Kbps]: 16263 1227
Attenuation [dB]: 28.5 14.5
Margins [dB]: 5.9 5.9
Output power [dBm]: 0.0 12.7
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 173
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 297 237
FEC: 211655 704
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 6118 N/A[/tt]
Re: Something wrong
02-03-2015 7:47 PM
Do you still have this intermittent noise on the line? Try the Quiet Line Test 17070 option 2 if need be.
Re: Something wrong
02-03-2015 8:19 PM
Here are stats. from about one and a half hours after previous ones:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 12:45:56
Failures:
Line PM: Near end
Error second (ES): 223
Bearer 0:
Code Violation (CV): 364 257
FEC: 228000 787
Bearer 0:
HEC violation count (HEC): 7312 N/A
[/tt]
Re: Something wrong
02-03-2015 8:23 PM
Re: Something wrong
02-03-2015 8:39 PM
If just that source, then it is likely that the problem is on their line.
