Something not quite right.
- Re: Something not quite right.
15-04-2014 8:25 AM
I have screenshots of the BT test and my PN profile, but given the problems with loading pictures, I'll just log the details here.
Connection speed increased from 8730 to 10570kbps
Downstream SNR reduced from around 13.5dB to 6-6.5dB
BT speed test 5.44Mbps down/0.36Mbps up
IP profile on BT test 9.32/0.83
Current line speed from members centre 9.3Mbps
For info, I was getting around 6/6.5 down/0.70up regularly prior to 10PM last night.
Any thoughts, anyone?
As a point of interest, I, personally, haven't rebooted for 20 days.
15-04-2014 9:01 AM
I've taken a look at your line and it looks pretty much spot on.
Are you currently using a wired connection?
15-04-2014 9:26 AM
15-04-2014 10:36 AM
My connection is wireless atm, but I bet (from previous experience) that if I went and booted the desktop which is wired, my results would be as near the same as makes no difference.
My line should be near spot-on - the BT guy who sorted my problem last month spent a while on the job.
Had another unplanned resync at roughly 0915 today and now get:
Connection speed: 7.685Mbps
D/S SNR : 11.5 - 12.5dB
BT speed test: 6.4Mbps/0.49Mbps
BT IP profile: 6.75Mbps/0.83Mbps
Current line speed in Members centre 9.3Mbps
Router Stats: Down Up
Attn 35.0 16.0
Speed 7.658 0.828
SNR 12.4 8.5
Go figure
And, as a point of interest, the forums are like treacle again.
15-04-2014 11:15 AM
<img src="http://community.plus.net/visualradius/generated/image1397556167815.png"/>
Have you noticed if you've had any interference on your phone line at all? Try a quiet line test by dialing 17070 then option 2.
15-04-2014 11:28 AM
Emma mentioned you wanted a test-socket BT speed test - I'll do that after lunch as I've a few things I need to do this morning, and connecting to the test socket involves a bit of furniture reorganisation.
15-04-2014 11:33 AM
15-04-2014 12:21 PM
Edit:
Found a small table and extension power lead, so 48 hours (max) in the test socket is a maybe - but it would still be wireless after the tests have been run.
15-04-2014 1:36 PM
Quote connecting to the test socket involves a bit of furniture reorganisation. Smiley
How are you currently set up, is it in an extension socket or using an extension cable?
15-04-2014 1:41 PM
16-04-2014 8:27 AM
Anyway, I appear to have had at least one DLM resync overnight (RADIUS logs will show any more ).
Can you tell me exactly what reports you want from a wired test socket report please, and I will do them asap. I expect my speed/SNR will change again as soon as I move the router.
16-04-2014 9:10 AM
Another Chris here - just to confuse things further
With your connection i the Test Socket we'll be able to rule out any internal wiring causing any potential interference which might be causing the drops/re-syncs. We'll also be able to look at the line stats in comparison to those taken before going into the Test Socket.
16-04-2014 9:22 AM
OK Chris #3 - I'll move into the test socket in a while and run the BT test - but I think you will find it's not my internal wiring - the last BT engineer ran loads of internal checks before he changed cab and exchange connections and didn't find anything.
16-04-2014 3:00 PM
Router is now in test socket, where I'll leave it until Friday mid-morning. RADIUS logs will show lots of disconnects I'm afraid - looks like my Netgear DG834Gv5 is dying.
Spoke to another Chris this morning, and he is arranging for a Thompson to be sent., as I'm such a good customer
In the meantime, I'm going to substitute a Sumvision router I was given - it is brand new, but as no-one seems to know much about this brand, I don't know what to expect.
Unfortunately, that will disconnect me again.
16-04-2014 3:12 PM
