turn on suggestions
Something Strange?
- Something Strange?
Something Strange?
Something Strange?
13-12-2007 2:18 PM
I recently asked for interleaving to be turned off.
Now I'm getting much lower pings and the advance stats on my router seem to be showing fast path being used.
BusyBox v0.61.pre (2007.04.16-10:12+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# cat /proc/avalanche/avsar_modem_stats
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 448 DS Connection Rate: 8128
DS Line Attenuation: 22 DS Margin: 11
US Line Attenuation: 10 US Margin: 24
US Payload : 1818838704 DS Payload: 15377283
84
US Superframe Cnt : 7454331 DS Superframe Cnt: 7454331
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 0 Severely Err Secs: 0
Frame mode: 3 Max Frame mode: 0
Trained Path: 0 US Peak Cell Rate: 1056
Trained Mode: 3 Selected Mode: 1
ATUC Vendor Code: 54535443 ATUC Revision: 2
Hybrid Selected: 3 Trellis: 1
Showtime Count: 3 DS Max Attainable Bit Rate: 10304 kbps
BitSwap: 1 US Max Attainable Bit Rate: n/a
Annex: AnxA psd_mask_qualifier: 0x0000
ATUC ghsVid: b5 00 54 53 54 43 00 00
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 1
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 6 FEC: 77 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
CRC: 260 FEC: 0 NCD: 0
LCD: 0 HEC: 0
However I now seem to have a new icon added to my 'connection settings' on the portal members page. - broadband interleaving - when I click on it - it says interleaving is ON!
seems strange...
[DSL Modem Stats]
84
LCD: 0 HEC: 0
LCD: 0 HEC: 0
LCD: 0 HEC: 0
LCD: 0 HEC: 0
seems strange...
Re: Something Strange?
13-12-2007 5:16 PM
That will be because our internal system hasn't picked up from BT that interleaving is off. I'll make the manual adjustment now and if you look in 5 mins or so it should show as 'off' or remove the icon completely.
Chris Parr Plusnet Staff |
13-12-2007 5:32 PM
Many thanks for the reply - it has indeed vanished now!
I was just worried interleaving might have been re-applied.
Thank you for the speedy response.
