Some sites will not work for me.
Exsert
Re: Some sites will not work for me.
okay thanks
spraxyt
Resting Legend
Fixes: 75
Quote from: Bob
Strange. That router [atlnode1.theservercompany.com [207.210.66.194]] doesn't appear anywhere in my traceroute suggesting that your traffic's taking a different path.
It's the one immediately before the destination atlsrv2.theservercompany.com [207.210.66.195] for me, and I have no problems accessing (either) website.
David
bobpullen
Fixes: 316
Just as an aside, you're not connected to a company VPN or anything like that are you (ie. accessing your work systems from home)?
Exsert
No i don't sorry ^
Chris
Legend
Fixes: 169
The next step then is for us to dialtest as yourself, if you can give us a 30 minute window (at least) when your router will be disconnected we'll be able to try those sites from here using your connection details. I'd suggest that tomorrow may be the most suitable time if you can arrange this.
Exsert
okay at what time would be best for you?
Chris
Legend
Fixes: 169
Myself and Bob are here 9.00-5.30 weekdays, however if you need it to be outside these times we can arrange one of the CSC to perform the test and pass the results on to us.
Exsert
9.30 would be a good time for me is that okay?
amcclean
I can access both sites from here on my pn connection.
Podman
bobpullen
Fixes: 316
Quote from: Exsert
9.30 is fine. Looks like there were problems with Linx yesterday and whilst we no longer peer with them directly this will have had the potential to have affected a lot of UK Internet traffic.
Are you still having the problem?
Edit: Correction to the above. We do still peer with Linx. I was confusing them with Level 3. Doh!
Chris
Legend
Fixes: 169
I was just about to test this, however it seems your router is still connected. Can you let us know when you will be able to disconnect this and we'll try again. Thanks.
Exsert
yeah links still don't work, i will turn the connection off now so you can acsess it.
Im very satisfied for the help youv'e given so far Cheesy
godsell4
Those 2 links work fine for me. Sad
tracert www.syhte.org
Tracing route to www.syhte.org [208.87.149.250]
over a maximum of 30 hops:
  1    2 ms    2 ms    2 ms  www.routerlogin.com [192.168.0.55]
  2    39 ms    25 ms    27 ms  lo0-plusnet.ptn-ag2.plus.net [195.166.128.53]
  3    25 ms    27 ms    26 ms  ge0-0-0-204.ptn-gw02.plus.net [84.92.3.93]
  4    27 ms    25 ms    26 ms  te2-2.pte-gw2.plus.net [212.159.1.106]
  5    26 ms    26 ms    26 ms  gsr12012.lon.he.net [195.66.224.21]
  6    *        *        *    Request timed out.
  7    *        *        *    Request timed out.
  8    *      175 ms  175 ms  ed-pri.firstlook.com [206.51.38.81]
  9  176 ms  174 ms  175 ms  208.87.149.250
Trace complete.
Hopefully Bob will find out why you can not with his testing.
SW.
3Mb FTTC
bobpullen
Fixes: 316
I can still trace to your IP address which would suggest you're still online  Sad
Exsert
Do i just disable my internet connection?
