Some sites slow?????????
- Some sites slow?????????
- « Previous
- 1
- 2
- Next »
Re: Some sites slow?????????
02-10-2008 6:18 PM
Hi
Websites retrieval is ok with me but trace routes still showing upto 131 ms latency at AOL Transit Data Network (ATDN) nodes (lossy)
This website allows you to check latency from specific routers for telia.net (go for london one)
for fans of historical router latency over the past 24 hours, check Router Watch
Rami out of cigs!
Rami out of cigs!
Message 16 of 21
(345 Views)
02-10-2008 6:24 PM
@tangey,
My traces timeout at similar places but I've no problems accessing CNN and eBay this evening.
Message 17 of 21
(345 Views)
02-10-2008 6:58 PM
The timeouts could of course be related to firewalls installed at those points, right Bob?
A good site I found a while back for a good overview of the health of the net is http://internettrafficreport.com/
Message 18 of 21
(345 Views)
02-10-2008 9:04 PM
Yes, the traceroute is not responding because the firewalls are dropping the ICMP packets. If you use tcp packets cisco responds (with delay mind you) fine:
From the above you can see that the final hop almost doubles the delay. Similar results are obtained from ebay.
# tcptraceroute -w 2 -q 1 -f 3 --track-port --dnat www.cisco.com
Tracing the path to www.cisco.com (198.133.219.25) on TCP port 80 (http), 30 hops max
3 vl703.thn-gw2.plus.net (84.92.4.242) 35.565 ms
4 ldn-b4-link.telia.net (213.248.84.197) 43.401 ms
5 ldn-bb1-link.telia.net (80.91.251.18) 32.389 ms
6 nyk-bb2-link.telia.net (80.91.248.254) 104.002 ms
7 nyk-b5-link.telia.net (80.91.248.158) 100.781 ms
8 192.205.34.53 134.353 ms
9 tbr1.n54ny.ip.att.net (12.122.105.46) 177.852 ms
10 cr1.n54ny.ip.att.net (12.122.16.201) 181.801 ms
11 cr1.cgcil.ip.att.net (12.122.1.190) 180.030 ms
12 cr1.sffca.ip.att.net (12.122.4.121) 176.324 ms
13 12.123.15.1 169.802 ms
14 12.118.124.10 167.952 ms
15 sjck-dmzbb-gw1.cisco.com (128.107.239.9) 185.364 ms
16 sjck-dmzdc-gw1-gig2-1.cisco.com (128.107.224.65) 185.221 ms
17 www.cisco.com (198.133.219.25) [open] 311.538 ms
Message 19 of 21
(345 Views)
02-10-2008 9:58 PM
Just trying to head off the question of why it drops at certain points
Message 20 of 21
(345 Views)
02-10-2008 10:03 PM
Quote from: MickKi From the above you can see that the final hop almost doubles the delay. Similar results are obtained from ebay.
Here's mine:
C:\Users\Bobby>tracetcp www.cisco.com
Tracing route to 198.133.219.25 [www.cisco.com] on port 80
Over a maximum of 30 hops.
1 1 ms 1 ms 1 ms 192.168.1.1 [home.gateway]
2 21 ms 28 ms 35 ms 195.166.128.27 [lo0-plusnet.pcl-ag01.plus.net]
3 30 ms 33 ms 142 ms 84.92.5.57 [gi1-2-803.pcl-gw1.plus.net]
4 79 ms 20 ms 29 ms 213.200.79.233 [xe-1-2-0-0.lon20.ip.tiscali.net
5 111 ms 112 ms 114 ms 213.200.81.89 [so-0-0-0.was11.ip.tiscali.net]
6 102 ms 107 ms 101 ms 213.200.84.94
7 178 ms 224 ms 189 ms 151.164.41.165 [ded4-g8-3-0.sntc01.pbi.net]
8 190 ms 184 ms 181 ms 64.161.0.62 [Cisco-Systems-1152786.cust-rtr.
pacbell.net]
9 191 ms 179 ms 176 ms 128.107.224.109 [sjc12-dmzbb-gw1-gig1-42.cisco.c
om]
10 218 ms 277 ms 188 ms 128.107.224.166 [sjck-dmzbb-gw1-g1-35.cisco.com]
11 178 ms 222 ms 194 ms 128.107.224.65 [sjck-dmzdc-gw1-gig2-1.cisco.com
12 Destination Reached in 197 ms. Connection established to 198.133.219.25
Trace Complete.
And this is on BT Retail's network:
1 2 ms 1 ms 1 ms 192.168.1.1 [home.gateway]
2 10 ms 9 ms 9 ms 217.47.73.142 [esr3.sheffield3.broadband.bt.ne
t]
3 10 ms 9 ms 10 ms 217.47.73.13
4 11 ms 9 ms 10 ms 217.47.110.6
5 10 ms 10 ms 11 ms 217.41.176.25
6 9 ms 9 ms 9 ms 217.41.176.66
7 10 ms 10 ms 10 ms 217.41.176.134
8 12 ms 11 ms 9 ms 217.41.176.46
9 11 ms 10 ms 9 ms 217.47.19.50
10 11 ms 79 ms 135 ms 217.32.171.181 [core1-pos4-1.sheffield.ukcore.b
t.net]
11 13 ms 59 ms 173 ms 62.6.204.146 [core1-pos8-0.birmingham.ukcore.
bt.net]
12 17 ms 17 ms 16 ms 62.6.204.210 [core3-pos0-6-1-0.ealing.ukcore.
bt.net]
13 17 ms 16 ms 16 ms 62.6.200.110 [transit1-gig8-0-0.ealing.ukcore
.bt.net]
14 17 ms 16 ms 16 ms 166.49.168.21 [t2c1-ge13-0-0.uk-eal.eu.bt.net]
15 102 ms 101 ms 102 ms 166.49.164.65 [t2c1-p5-0-0.us-ash.eu.bt.net]
16 97 ms 95 ms 96 ms 206.223.115.78 [ex1-g2-0.eqabva.sbcglobal.net]
17 167 ms 166 ms 168 ms 151.164.41.165 [ded4-g8-3-0.sntc01.pbi.net]
18 * 172 ms 173 ms 64.161.0.62 [Cisco-Systems-1152786.cust-rtr.
pacbell.net]
19 171 ms 170 ms 170 ms 128.107.224.109 [sjc12-dmzbb-gw1-gig1-42.cisco.c
om]
20 170 ms 170 ms 170 ms 128.107.224.166 [sjck-dmzbb-gw1-g1-35.cisco.com]
21 173 ms 172 ms 172 ms 128.107.224.77 [sjck-dmzdc-gw2-gig2-1.cisco.com
22 Destination Reached in 168 ms. Connection established to 198.133.219.25
Trace Complete.
Neither really indicative of a problem.
Message 21 of 21
(345 Views)
- « Previous
- 1
- 2
- Next »
