Some kind of meltdown this morning?
- Some kind of meltdown this morning?
18-06-2010 1:23 PM
Really odd.... this isn't actually an issue as such i'm just curious
Was there some kind of meltdown on the PN/BT systems at about lunchtime? I happened to run a speedtest, and found that my line was getting 2.3-3Mb out of the normal 6.5-7. Thought it was probably a dodgy gateway so I rebooted the router, still same speeds... so I tried a different speed test server and ran BT speed test too... still the same result.
Phoned up CSC and was told to start doing the usual 3 speed tests then raise a fault. and then suddenly about 15 minutes later everything fixed itself!
Very strange any ideas?
Message 1 of 5
(948 Views)
4 REPLIES 4
Re: Some kind of meltdown this morning?
18-06-2010 2:13 PM
Hi severedsolo,
Just checked our systems and not had any issues that we are aware of. So, no obvious explanations for that one I'm afraid!
Jojo
Jojo
Message 2 of 5
(503 Views)
18-06-2010 6:23 PM
Are not sports events taking a heavy toll of available bandwidth at the Exchanges?
Regards
Regards
Message 3 of 5
(503 Views)
18-06-2010 8:21 PM
Good point World Cup probably silly me.
Message 4 of 5
(503 Views)
21-06-2010 10:21 AM
I did come across this last week as a result of the world cup http://status.aaisp.net.uk/?incident=284
...you boys and your football
Message 5 of 5
(503 Views)
