Some help please :)
womby48
Some help please :)
Can someone explain what this means lol
Download speedachieved during the test was - 1797 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps    <---- why is this 2mb?
    Glenn.
Fixes: 62
Re: Some help please :)
i assume that you have just been connected to broadband and, if so, that is the explanation. The systems tend to start of with a default value and it can take a few days for it to be increased
leeanthony
think u jus gota wait mate, i aint no tech savvy person with adsl but basically jus leave ya router connected for some days/a week i duno an it will soon rise up, im sure u will get a more detailed response shortly Grin
ClaretMatt
In all probability you've had a few low sync events in quick succession and the DLM has lowered your IP profile in order to attempt to stabilise your line.  How long has your DSL been up for?
womby48
Thanks for the quick replys. My connection has been up for only 24 hours. Just had the phone line installed a week ago. So this IP profile limit should rise you think?
  Glenn.
HaydnExport
yes it should rise after 3 days i think
ClaretMatt
Ah, well in that case there's an initial 10-day training period in which your maximum stable line speed is determined. Provided your line is relatively error free you'll probably achieve the maximum possible profile for ADSL which is 7150
womby48
ADSL Link                      Downstream        Upstream
Connection Speed      8128 kbps            448 kbps
Line Attenuation            24 db                    13.5 db
Noise Margin                9 db                        28 db
Are these normal?
    Glenn
ClaretMatt
Looks fine so far
leeanthony
upto8mb
8128 kbps is the max so lucky u Sad
womby48
Just done another BT speed test and these are the results as you can see the IP profile has gone up loads but still only 2410 acheived this look normal for the pro package?
BT SpeedTest:
Download speedachieved during the test was - 2410 Kbps
IP Profile for your line is - 7150 Kbps
Plusnet Speedtest Site
Date                Download Speed               Upload Speed
Today 17:49   2331 kbps (291kB/s)        382 kbps (47.8kB/s)
Today 17:44   5779 kbps (722kB/s)        382 kbps (47.8kB/s)
Today 17:44   5665 kbps (708kB/s)        383 kbps (47.9kB/s)
Today 17:43   3500 kbps (438kB/s)        383 kbps (47.9kB/s)
Today 17:41   2524 kbps (316kB/s)        381 kbps (47.6kB/s)
Today 17:41   3481 kbps (435kB/s)        382 kbps (47.8kB/s)
Today 17:38   2879 kbps (360kB/s)        381 kbps (47.6kB/s)
Today 17:38   2453 kbps (307kB/s)        381 kbps (47.6kB/s)
Guessing this is randomness is down to me being the 2nd day into joining plusnet?
   Glenn.
ClaretMatt
It's probably because your "Plunet profile" hasn't caught up.  Expect max setting some time tomorrow
Re:Some help please :)
Hi womby,
I've just had a look at your account with the intention of moving you onto the 7150 profile, but it's already there. As you were only activated a couple of days ago it's probably going through the initial training period - I'd expect things to settle within the next few days.
