Some help and/or advice please . .?
- Some help and/or advice please . .?
22-06-2010 11:25 AM
My broadband connection, whilst not the fastest on the planet, has remained stable now at around 2Meg like forever. So when things slowed down a couple of weeks ago I put it down to Win Vista - as you would ;). After all, my PlusNet broadband is rock steady.:D. However, when I noticed the same sluggishness on my standby win XP machine I decided a speed test was in order. Imagine my horror when I found my download and upload speeds about the same!
I've just checked my profile on PlusNet and my estimated line speed, checked on 21/5/10 was 2000 (no surprise there) but my current line speed is down at 500. So there's the problem.
Now absolutely nothing, repeat nothing, has been changed in my house set-up. No phones added, wires moved or anything. The wireless router is directly plugged into a split master socket anyway so there is very little that can affect it. However, thinking back - we had a power cut around about the time things got slow, and the perceived "line drop" caused by the cut is more than likely what caused my profile to be adjusted.
So the question is, what is the best way to get this back up to the more normal 2000 I've had for donkey's? Do I raise a ticket , and if so what do I say on it to avoid it being treated as the "run of the mill" speed issue with all the attendant speed checking etc that would go with that? Or dare I hope that a sympathetic CS rep on here will jump in and "tweak" it for me - please?
Pretty pretty please?
Barrie
Re: Some help and/or advice please . .?
22-06-2010 11:37 AM
Quote from: essenby Now absolutely nothing, repeat nothing, has been changed in my house set-up.
It's more than 90% certain that it has, but you're just not aware.
e.g. damaged cables, corroded joints, thermal expansion etc. etc.
Moved any furniture, had any carpets relaid?
Your router stats from the BT Test Socket would be informative.
22-06-2010 11:54 AM
You've been connected for over 6 days, i've just tested the line and can only see 704k sync. I'd be interested to see what it'd be like after a reboot. If you could do that and get back to me I'll check it again.
Jojo
22-06-2010 12:31 PM
No furniture moved or carpets laid. And unfortunately router stats are not possible unless you can advise me differently? For my sins (and stupidity) when my Linksys WAG54GS started playing up I replaced it with a Belkin F5D7632uk4 and nothing I have tried has been successful in obtaining stats from it
@JoJo
Thanks for checking - I'll re-boot the router tonight when I get home. You did mean the router right - rather than the laptop
22-06-2010 12:41 PM
Have you tried the guides for Belkin at http://www.kitz.co.uk/adsl/frogstats.php
I know your model isn't listed but others seem to have had some success.
22-06-2010 1:05 PM
22-06-2010 1:10 PM
Quote from: essenby
@JoJo
Yes, lol, the router
22-06-2010 2:42 PM
http://192.168.2.1/index.stm
http://192.168.2.1/ADSL_status_main.stm
http://en-uk-support.belkin.com/app/answers/detail/a_id/776/q/routers
22-06-2010 6:16 PM
However - just done a speed test on SpeedTest.Net and it's still only around a quarter of what I expected:-
My PlusNet profile is still showing 500 - will that change or does someone have to kick it?
@Hary
Thanks for th help but no joy. All I get is :-
Can't open file ADSL_status_main.stm
23-06-2010 12:02 PM
just checked BT systems and your profile was raised today, so I have brought ours into line with it.
Jojo
23-06-2010 1:01 PM
23-06-2010 1:18 PM
Jojo
23-06-2010 1:45 PM
(just got the router stats issue to sort out now :D)
27-06-2010 1:44 PM
27-06-2010 7:33 PM
http://www.mybroadbandspeed.co.uk/
