Some PlusNet router settings don't survive power off/on
offbeatdave
Although I'm not convinced it makes any difference, I disable the 'power reduction' wireless setting in the Thomson TG582N router. However, I've noticed that when I reboot the router it magically re-enables itself. It does this whether disabled through the web interface or via Telnet (remembering to use the 'saveall' command).
It has also happened a couple of times with the uPnP setting too.
Has anyone else noticed this phenomenon? Can it be prevented?
