[Solved] Technicolor TG582n R10 Firmware
rogersouthern
I just upgraded to the R10 firmware for my router, and I am currently adding my 2nd SSID by following http://npr.me.uk/mssid.html.
It follows the usual setup up until when I run the wireless mssid ifconfig command, it asks the following extra configuration questions that I am not sure how to answer.
[maxassociations]=
[WPAradiuskey]=
[WPArekeysec]=
[WPAradiusip]=
[WPAradiusport]=
[WPAradiusto]=
[WPAversion]=
[stationhistory]=
[convertmcast4]=
[convertmcast6]=
[convertbcast]=
If anyone knows that these mean or what I should answer for them, please say!
Fixes: 5
Re: Technicolor TG582n R10 Firmware
If you use the following command you can see the default settings used by the master mssid:
wireless mssid iflist ssid_id=0
You can leave those unknown settings blank if you wish and the router will automatically enter the default settings for them.
rogersouthern
Ah, NPR, probably the best person to answer!
Thanks for that, I forgot to check whether or not I could just leave it black Smiley
dick:quote
