Solid orange light
alexmakel
Solid orange light
Our router is displaying a solid orange light. We have tried restarting the hub, factory resetting the hub & also turning the power on and off.
We have also tried accessing the hub manager online to check that our details are correct ([email protected]) but it will not let me connect my router to the internet. It will also only let us connect to the page when the DSL cable is unplugged, otherwise it says ‘PPP CONNECTING’ but does not load.
Can somebody please advise how to fix this as we seem to have tried most fixes and all helplines are now closed?
10 REPLIES 10
Fixes: 387
Re: Solid orange light
@alexmakel Is this by any chance a new connection, or is it a failure of a previously active one? Which Hub are you using?
alexmakel
Hi John,
It’s a previously active unit, we’ve had it for 4 years and not had this issue before, very strange.
It’s a hub one router.
Thanks in advance for your help.
Fixes: 387
Thanks for confirming the Hub model. Which of the conditions in the list below fits your lights?
alexmakel
Hi John,
None of the above unfortunately.
Power light (LED 1) is staying orange but no other lights are flashing or displaying an error code.
Fixes: 387
In that case, I'm stumped - hopefully someone else may have an idea, but it may be tomorrow before anyone picks this up.
paul_blitz
Fixes: 4
Is this a Hub 1 (long thin main LED, other LEDs below) or a hub 2 (nice big circular LED)?
Fixes: 387
@paul_blitz - see post #3
paul_blitz
Fixes: 4
Sorry, I'll try reconnecting my eyes, see if they see better 🙂
@alexmakel
Have you a cable plugged into the WAN port, for a DSL connection this should not be used.
alexmakel
Hi Dan,
No cable plugged into the WAN port at all.
Thanks,
Alex
