Solid orange light and flashing broadband symbol
aforrester08
My router this morning suddenly lost broadband and started flashing the B symbol appeared on it. I have been through all the troubleshooting steps, restart, factory reset, on & off, checking if service is down in the area and nothing has helped. is it possible to check my line and see what is happening?
Thanks,
Alex
7 REPLIES 7
Fixes: 334
Re: Solid orange light and flashing broadband symbol
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
SammyM
Fixes: 101
Hiya @aforrester08
I'm sorry you are having issues with your connection, I can see you have raised a fault and they will keep you updated Smiley
 Sammy M - Sheffield Team
aforrester08
Thank you, on the online ticket it now say "This Question is now on hold until Saturday 2nd December at 7:00am.". Could you find out why this is please?
Fixes: 334
Standard Openreach 72hr SLA
aforrester08
Does that mean it's still being worked on though?
Fixes: 334
Yes
Fixes: 459
@aforrester08
It means that Openreach have accepted that there is a problem and aim to fix it some time in the next 3 days.
