Solid connection for 100+ days, then all afternoon and into late pm, multiple disconnects.
Gel
Aspiring Champion
Fixes: 29
Any ideas what would be cause of multiple disconnects, as in subject line?
I'm on long line at end of our village; current speed is good for my location.
13 REPLIES 13
DS
Seasoned Champion
Fixes: 22
Re: Solid connection for 100+ days, then all afternoon and into late pm, multiple disconnects.
If you click this and select WAN from the drop down menu, is there nothing obvious showing?
As an example, here's a few of mine:
17:42:50, 03 Jan. ( 132.390000) PPPoE is up -​ Down Rate=30632Kbps, Up Rate=2001Kbps; SNR Margin Down=6.1dB, Up=10.1dB
17:42:00, 03 Jan. ( 82.110000) PTM over DSL is up
17:41:11, 03 Jan. ( 32.470000) WAN Auto-​sensing running.
These (above) can be created when we power the hub up.
10:51:02, 05 Jan. ( 125.040000) PPPoE is up -​ Down Rate=31415Kbps, Up Rate=2001Kbps; SNR Margin Down=6.1dB, Up=10.2dB
10:51:02, 05 Jan. ( 125.030000) CHAP authentication successful
10:51:02, 05 Jan. ( 124.950000) CHAP Receive Challenge
10:51:02, 05 Jan. ( 124.950000) Starting CHAP authentication with peer
10:51:02, 05 Jan. ( 124.950000) PPP LCP Receive Configuration ACK
10:51:02, 05 Jan. ( 124.940000) PPP LCP Send Configuration Request
10:51:02, 05 Jan. ( 124.940000) PPP LCP Receive Configuration Reject
10:51:02, 05 Jan. ( 124.940000) PPP LCP Send Configuration ACK
10:51:02, 05 Jan. ( 124.930000) PPP LCP Receive Configuration Request
10:51:02, 05 Jan. ( 124.930000) PPP LCP Send Configuration Request
10:50:12, 05 Jan. ( 75.310000) PTM over DSL is up
10:49:32, 05 Jan. ( 34.520000) WAN Auto-​sensing running.
17:45:46, 03 Jan. ( 126.930000) WAN operating mode is VDSL
17:45:46, 03 Jan. ( 126.930000) Last WAN operating mode was VDSL
17:45:45, 03 Jan. ( 125.590000) PPP IPCP Receive Configuration ACK
17:45:45, 03 Jan. ( 125.580000) PPP IPCP Send Configuration Request
17:45:45, 03 Jan. ( 125.580000) PPP IPCP Receive Configuration NAK
17:45:45, 03 Jan. ( 125.580000) PPP IPCP Send Configuration ACK
17:45:45, 03 Jan. ( 125.580000) PPP IPCP Receive Configuration Request
17:45:45, 03 Jan. ( 125.570000) PPP IPCP Send Configuration Request
17:45:43, 03 Jan. ( 124.440000) PPPoE is up -​ Down Rate=30566Kbps, Up Rate=2001Kbps; SNR Margin Down=6.1dB, Up=10.1dB
17:45:43, 03 Jan. ( 124.420000) CHAP authentication successful
17:45:43, 03 Jan. ( 124.310000) CHAP Receive Challenge
17:45:43, 03 Jan. ( 124.310000) Starting CHAP authentication with peer
17:45:43, 03 Jan. ( 124.310000) PPP LCP Receive Configuration ACK
17:45:43, 03 Jan. ( 124.300000) PPP LCP Send Configuration Request
17:45:43, 03 Jan. ( 124.300000) PPP LCP Receive Configuration Reject
17:45:43, 03 Jan. ( 124.300000) PPP LCP Send Configuration ACK
17:45:43, 03 Jan. ( 124.290000) PPP LCP Receive Configuration Request
17:45:43, 03 Jan. ( 124.290000) PPP LCP Send Configuration Request
17:44:54, 03 Jan. ( 74.770000) PTM over DSL is up
I can get multiples of these when my hub attempts to reconnect, though I don't why the hub doesn't connect the first time.
14:08:14, 05 Jan. (11942.420000) PPPoE is down after 196 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 -​ Down)]
14:08:12, 05 Jan. (11939.580000) PPP LCP Send Termination Request [User request]
I can't remember the above, so not too sure what triggers this
13:42:02, 18 Jan. (1101249.400000) PPPoE is down after 8657 minutes uptime [In Progress...]
13:41:58, 18 Jan. (1101245.480000) PPP LCP Send Termination Request [User request]
I can cause this event via My Portal
14:36:07, 22 Jan. (1450093.780000) PPPoE is down after 3452 minutes uptime [Disconnected]
14:36:04, 22 Jan. (1450091.230000) PPP LCP Send Termination Request [PPPoE PADT received]
And I believe these are caused when we upload to the www - PN are aware and have sent a fix to some users.
Gel
Aspiring Champion
Fixes: 29
Thanks; unfortunately that link address doesn't work for my set up; however, some data here, which
hopefully relevant:
21:21:19, 30 Jan. (10443820.000000) ATM over DSL is up
21:20:22, 30 Jan. (10443763.280000) ATM over DSL is down after 0 minutes uptime
21:20:22, 30 Jan. (10443763.280000) ETHoA is down after 0 minutes uptime
21:20:20, 30 Jan. (10443760.900000) PPP LCP Send Termination Request [User request]
21:20:19, 30 Jan. (10443759.860000) PPP LCP Send Configuration Request
21:20:16, 30 Jan. (10443756.860000) PPP LCP Send Configuration Request
21:20:09, 30 Jan. (10443750.220000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=2988Kbps, Up Rate=843Kbps; SNR Margin Down=6.2dB, Up=6.0dB
21:20:09, 30 Jan. (10443750.220000) ATM over DSL is up
21:19:45, 30 Jan. (10443726.100000) CWMP: session closed due to error: Could not resolve host
21:19:45, 30 Jan. (10443726.080000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
21:19:45, 30 Jan. (10443726.070000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:19:15, 30 Jan. (10443695.820000) CWMP: session closed due to error: Could not resolve host
21:19:15, 30 Jan. (10443695.800000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
21:19:15, 30 Jan. (10443695.790000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
21:19:14, 30 Jan. (10443695.530000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
21:19:12, 30 Jan. (10443693.430000) ATM over DSL is down after 132 minutes uptime
21:19:12, 30 Jan. (10443693.430000) ETHoA is down after 132 minutes uptime
18:49:43, 30 Jan. (10434724.190000) ATM over DSL is down after 115 minutes uptime
18:49:43, 30 Jan. (10434724.190000) ETHoA is down after 115 minutes uptime
18:49:43, 30 Jan. (10434724.190000) PPPoA is down after 115 minutes uptime [Waiting for Underlying Connection (WAN ATM over DSL -​ Down)]
18:49:40, 30 Jan. (10434721.410000) PPP LCP Send Termination Request [User request]
16:54:19, 30 Jan. (10427800.450000) WAN operating mode is ADSL
16:54:19, 30 Jan. (10427800.450000) Last WAN operating mode was ADSL
16:54:18, 30 Jan. (10427799.070000) PPP IPCP Receive Configuration ACK
16:54:18, 30 Jan. (10427799.070000) PPP IPCP Send Configuration ACK
16:54:18, 30 Jan. (10427799.070000) PPP IPCP Receive Configuration Request
16:54:18, 30 Jan. (10427799.060000) PPP IPCP Send Configuration Request
16:54:15, 30 Jan. (10427796.060000) PPP IPCP Send Configuration Request
16:54:15, 30 Jan. (10427796.050000) PPP IPCP Receive Configuration NAK
16:54:15, 30 Jan. (10427796.030000) PPP IPCP Send Configuration Request
Mustrum
Fixes: 77
It might be worth starting with the basics, and do a quiet line test on the phone, is it quiet?
After that you have the links in your signature, you know what to do.
DS
Seasoned Champion
Fixes: 22
After or during the tests suggested above, if you recall, was there any wet or windy weather last night?
The only thing I've noticed is that the noise margin is different in both of your images. If these were taken some time apart then ignore this. But if they were taken with a short time in between, then it might be worth watching this again tonight.
note: It is normal for the dB to drop during the night.
A farmer that I knew (he was right out there on the end of a very long line) had issues were his SNR would erode to 0dB and would drop the connection and reconnect.
Although this would not have any bearing, because the link didn't work (above), I presume you using the other IP address range.
Gel
Aspiring Champion
Fixes: 29
DS
Seasoned Champion
Fixes: 22
The main thing is that the connection didn't drop Smiley
It could have been a blip or an issue that was discovered and fixed remotely....?
See how it goes over the next few days, don't become paranoid about it, but keep and eye on the snr, just in case it drops too low during the day.
Chris
Legend
Fixes: 169
It's unlikely that we'll know what cause a spell of intermittent connections, this could have been so many things anywhere along the line. However as you've said, all looks stable again:
Gel
Aspiring Champion
Fixes: 29
Gel
Aspiring Champion
Fixes: 29
After 6.15pm seeing multiple disconnects again; any clue in log?Huh
Recorded events
Time and date Message
18:27:02, 01 Feb. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [172.16.0.79]:50882-​>[52.51.112.191]:443 on ppp0)
18:27:01, 01 Feb. (10606155.990000) Admin login successful by 172.16.0.64 on HTTP
18:26:55, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.28.40.145]:443-​>[80.]:53738 on ppp0)
18:26:54, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.28.40.145]:443-​>[80.]:53719 on ppp0)
18:26:51, 01 Feb. (10606146.460000) Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any-​>54071, internal ports: 54071, internal client: 172.16.0.64
18:26:50, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.28.40.145]:443-​>[80.]:53738 on ppp0)
18:26:50, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.28.40.145]:443-​>[80.]:53719 on ppp0)
18:26:48, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.28.40.145]:443-​>[80.]:53738 on ppp0)
18:26:48, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [52.28.40.145]:443-​>[80.]:53719 on ppp0)
18:26:44, 01 Feb. (10606139.310000) Lease for IP 172.16.0.64 renewed by host Dell_XPS (MAC 5c:51:4f:7b:af:70). Lease duration: 30240 min
18:26:44, 01 Feb. (10606139.310000) Device connected: Hostname: Dell_XPS IP: 172.16.0.64 MAC: 5c:51:4f:7b:af:70 Lease time: 30240 min. Link rate: 866.6 Mbps
18:26:44, 01 Feb. (10606139.240000) Lease requested
18:26:44, 01 Feb. ath10: STA 5c:51:4f:7b:af:70 IEEE 802.11: Client associated
18:26:02, 01 Feb. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [172.16.0.79]:38923-​>[52.213.62.63]:443 on ppp0)
18:25:45, 01 Feb. (10606080.030000) CWMP: session completed successfully
18:25:44, 01 Feb. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [172.16.0.79]:56287-​>[52.31.97.25]:443 on ppp0)
18:25:44, 01 Feb. (10606079.860000) CWMP: HTTP authentication success from https://dbtpnhdm.bt.mo
18:20:35, 01 Feb. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [172.16.0.79]:53772-​>[34.248.14.142]:30011 on ppp0)
18:25:38, 01 Feb. (10606073.150000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
18:25:38, 01 Feb. (10606073.140000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:25:36, 01 Feb. (10606071.150000) WAN operating mode is ADSL
18:25:36, 01 Feb. (10606071.150000) Last WAN operating mode was ADSL
18:25:34, 01 Feb. (10606069.790000) CWMP: session closed due to error: Could not resolve host
18:25:34, 01 Feb. (10606069.790000) PPP IPCP Receive Configuration ACK
18:25:34, 01 Feb. (10606069.780000) PPP IPCP Send Configuration ACK
18:25:34, 01 Feb. (10606069.780000) PPP IPCP Receive Configuration Request
18:25:34, 01 Feb. (10606069.780000) PPP IPCP Send Configuration Request
18:25:34, 01 Feb. (10606069.780000) PPP IPCP Receive Configuration NAK
18:25:30, 01 Feb. (10606064.960000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
18:25:30, 01 Feb. (10606064.950000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:25:30, 01 Feb. (10606065.660000) PPP IPCP Send Configuration ACK
18:25:30, 01 Feb. (10606065.660000) PPP IPCP Send Configuration Request
18:25:30, 01 Feb. (10606065.470000) PPP IPCP Receive Configuration Request
18:25:28, 01 Feb. (10606062.960000) WAN operating mode is ADSL
18:25:28, 01 Feb. (10606062.960000) Last WAN operating mode was ADSL
18:25:26, 01 Feb. (10606061.600000) PPP IPCP Send Configuration ACK
18:25:26, 01 Feb. (10606061.600000) PPP IPCP Receive Configuration Request
18:25:26, 01 Feb. (10606061.280000) PPP IPCP Receive Configuration ACK
18:25:26, 01 Feb. (10606061.270000) PPP IPCP Send Configuration Request
18:25:26, 01 Feb. (10606061.260000) PPP IPCP Receive Configuration NAK
18:25:26, 01 Feb. (10606061.250000) PPP IPCP Send Configuration Request
18:25:24, 01 Feb. (10606059.590000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=2952Kbps, Up Rate=871Kbps; SNR Margin Down=6.6dB, Up=4.2dB
18:25:24, 01 Feb. (10606059.570000) CHAP authentication successful
18:25:24, 01 Feb. (10606059.290000) CHAP Receive Challenge
18:25:24, 01 Feb. (10606059.290000) Starting CHAP authentication with peer
18:25:24, 01 Feb. (10606059.290000) PPP LCP Receive Configuration ACK
18:25:24, 01 Feb. (10606059.280000) PPP LCP Send Configuration ACK
18:25:24, 01 Feb. (10606059.280000) PPP LCP Send Configuration Request
18:25:24, 01 Feb. (10606059.280000) PPP LCP Receive Configuration Request
18:25:23, 01 Feb. (10606058.780000) CHAP Receive Challenge
18:25:23, 01 Feb. (10606058.780000) Starting CHAP authentication with peer
18:25:23, 01 Feb. (10606058.780000) PPP LCP Receive Configuration ACK
18:25:23, 01 Feb. (10606058.770000) PPP LCP Send Configuration Request
18:25:23, 01 Feb. (10606058.770000) PPP LCP Receive Configuration Reject
18:25:23, 01 Feb. (10606058.770000) PPP LCP Send Configuration ACK
18:25:23, 01 Feb. (10606058.770000) PPP LCP Receive Configuration Request
18:25:23, 01 Feb. (10606058.600000) PPP LCP Send Configuration Request
18:25:20, 01 Feb. (10606055.600000) PPP LCP Send Configuration Request
18:25:17, 01 Feb. (10606052.600000) PPP LCP Send Configuration Request
18:25:14, 01 Feb. (10606049.600000) PPP LCP Send Configuration Request
18:25:11, 01 Feb. (10606046.600000) PPP LCP Send Configuration Request
18:25:08, 01 Feb. (10606043.600000) PPP LCP Send Configuration Request
18:25:02, 01 Feb. (10606037.070000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=2952Kbps, Up Rate=871Kbps; SNR Margin Down=6.0dB, Up=6.0dB
18:25:02, 01 Feb. (10606037.070000) ATM over DSL is up
18:24:09, 01 Feb. (10605983.920000) ATM over DSL is down after 0 minutes uptime
18:24:09, 01 Feb. (10605983.910000) ETHoA is down after 0 minutes uptime
18:24:06, 01 Feb. (10605981.620000) PPP LCP Send Termination Request [User request]
18:24:06, 01 Feb. (10605981.620000) PPP LCP Send Configuration Request
18:24:03, 01 Feb. (10605978.620000) PPP LCP Send Configuration Request
18:24:00, 01 Feb. (10605975.620000) PPP LCP Send Configuration Request
18:23:54, 01 Feb. (10605969.090000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=3027Kbps, Up Rate=855Kbps; SNR Margin Down=6.0dB, Up=6.0dB
18:23:54, 01 Feb. (10605969.090000) ATM over DSL is up
18:23:01, 01 Feb. (10605915.950000) ATM over DSL is down after 0 minutes uptime
18:23:01, 01 Feb. (10605915.940000) ETHoA is down after 0 minutes uptime
18:22:58, 01 Feb. (10605913.640000) PPP LCP Send Termination Request [User request]
18:22:58, 01 Feb. (10605913.630000) PPP LCP Send Configuration Request
18:22:55, 01 Feb. (10605910.630000) PPP LCP Send Configuration Request
18:22:52, 01 Feb. (10605907.630000) PPP LCP Send Configuration Request
18:22:46, 01 Feb. (10605901.090000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=3032Kbps, Up Rate=856Kbps; SNR Margin Down=6.0dB, Up=6.1dB
18:22:46, 01 Feb. (10605901.090000) ATM over DSL is up
18:21:53, 01 Feb. (10605847.960000) ATM over DSL is down after 0 minutes uptime
18:21:53, 01 Feb. (10605847.960000) ETHoA is down after 0 minutes uptime
18:21:50, 01 Feb. (10605845.640000) PPP LCP Send Termination Request [User request]
18:21:49, 01 Feb. (10605844.640000) PPP LCP Send Configuration Request
18:21:46, 01 Feb. (10605841.640000) PPP LCP Send Configuration Request
18:21:44, 01 Feb. (10605839.830000) CWMP: session closed due to error: Could not resolve host
18:21:39, 01 Feb. (10605834.590000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=2968Kbps, Up Rate=863Kbps; SNR Margin Down=6.2dB, Up=6.0dB
18:21:39, 01 Feb. (10605834.590000) ATM over DSL is up
18:21:38, 01 Feb. (10605832.890000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
18:21:38, 01 Feb. (10605832.890000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:21:07, 01 Feb. (10605802.640000) CWMP: session closed due to error: Timeout
18:20:46, 01 Feb. (10605781.770000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
18:20:44, 01 Feb. (10605779.700000) ATM over DSL is down after 0 minutes uptime
18:20:44, 01 Feb. (10605779.700000) ETHoA is down after 0 minutes uptime
18:20:44, 01 Feb. (10605779.700000) PPPoA is down after 0 minutes uptime [Waiting for Underlying Connection (WAN ATM over DSL -​ Down)]
18:20:42, 01 Feb. (10605776.900000) PPP LCP Send Termination Request [User request]
18:20:32, 01 Feb. (10605767.830000) CWMP: Server URL: https://dbtpnhdm.bt.mo; Connecting as user: ACS username
18:20:32, 01 Feb. (10605767.820000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
18:20:30, 01 Feb. (10605765.820000) WAN operating mode is ADSL
18:20:30, 01 Feb. (10605765.820000) Last WAN operating mode was ADSL
DS
Seasoned Champion
Fixes: 22
18:25:38 to 18:27:02 are normal UPnP events. 18:20:35 should not be after the earlier time?!?!?
But take the image down or edit it as it's telling readers more than you may want them to know. If I tell you what and where others may see this before you have time to hide them.
18:20:30 to 18:25:30 shouldn't be happening that often. Refer to Mustrum's post, any noise etc?
Is @Chris still lurking?
Gel
Aspiring Champion
Fixes: 29
Noted. Tks.
No noise on line; have edited pasted data; out of order, as I couldn't seem to paste in order I wanted on forum.
Still up at moment, but Storm Doris make upset our overhead lines perhaps.
DS
Seasoned Champion
Fixes: 22
If you can still delete it, here's a clean one, posted for reference Wink
If you can't delete it, flag a mod and ask for it to be removed Smiley
(I did flag it myself just after posting my reply above, but they may not have seen it yet)
18:27:02, 01 Feb. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [172.16.0.79]:50882-​>[removed]:443 on ppp0)
18:26:55, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [removed]:443-​>[80.]:53738 on ppp0)
18:26:54, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [removed]:443-​>[80.]:53719 on ppp0)
18:26:50, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [removed]:443-​>[80.]:53738 on ppp0)
18:26:50, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [removed]:443-​>[80.]:53719 on ppp0)
18:26:48, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [removed]:443-​>[80.]:53738 on ppp0)
18:26:48, 01 Feb. IN: BLOCK [9] Packet invalid in connection (Invalid tcp flags for current tcp state: TCP [removed]:443-​>[80.]:53719 on ppp0)
18:26:44, 01 Feb. (10606139.310000) Lease for IP 172.16.0.64 renewed by host Dell_XPS (MAC removed). Lease duration: 30240 min
18:26:44, 01 Feb. (10606139.310000) Device connected: Hostname: Dell_XPS IP: 172.16.0.64 MAC: removed Lease time: 30240 min. Link rate: 866.6 Mbps
18:26:44, 01 Feb. ath10: STA removed IEEE 802.11: Client associated
18:26:02, 01 Feb. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [172.16.0.79]:38923-​>[removed]:443 on ppp0)
18:25:44, 01 Feb. OUT: BLOCK [9] Packet invalid in connection (tcp reset attack is suspected: TCP [172.16.0.79]:56287-​>[removed]:443 on ppp0)
18:20:35, 01 Feb. OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [172.16.0.79]:53772-​>[removed]:30011 on ppp0)
DS
Seasoned Champion
Fixes: 22
DS wrote: Is @Chris still lurking?
(Coughs his name in the hope he can check if anything is showing at his end) Roll_eyes
