So whats actully happening to customers broadband speeds?
- So whats actully happening to customers broadband ...
- « Previous
- Next »
Re: So whats actully happening to customers broadband speeds?
01-05-2014 1:43 PM
Interleaving has automatically been applied to your line, this may be due to a few errors on the line which would have caused the line to band had Interleaving not been applied.
To be honest, you're best leaving it on to prevent banding - I appreciate that your ping times are higher as a result, but it's probably best to have good stability. On the flip side, we could move you onto a different Stability Option to try and give your line different variables so that it gives the line a little more leeway when/if the line does error with Interleaving Off.
Message 61 of 65
(328 Views)
01-05-2014 3:51 PM
Message 62 of 65
(328 Views)
01-05-2014 4:37 PM
I've placed an order to make the change, the order should complete in the early hours of tomorrow morning.
If Interleaving is still on tomorrow, let me know and I'll see if I can get that removed for you.
Message 63 of 65
(328 Views)
01-05-2014 5:13 PM
ok mate thanks.
Message 64 of 65
(328 Views)
06-05-2014 1:57 PM
Message 65 of 65
(328 Views)
- « Previous
- Next »
