So whats actully happening to customers broadband speeds?
- So whats actully happening to customers broadband ...
Re: So whats actully happening to customers broadband speeds?
22-04-2014 2:32 PM
22-04-2014 4:25 PM
That same thing was happening to me a week ago, so ive just checked my dns settings and needed to set them back to the ones stated, I did update my firmware about a month ago so wonder if this may have changed them. I use the Netgear DGN2200v3 Router.
Btw chris have you put my interleaving Off request in yet ?
22-04-2014 5:06 PM
22-04-2014 5:57 PM
22-04-2014 6:19 PM
22-04-2014 6:29 PM
22-04-2014 7:52 PM
23-04-2014 12:26 AM
23-04-2014 3:38 AM
23-04-2014 12:07 PM
25-04-2014 8:27 PM
25-04-2014 10:51 PM
26-04-2014 1:05 AM
26-04-2014 1:50 AM
29-04-2014 1:45 PM
Ok can someone check if interleaving is still off on my connection, because it was turned off 2 week ago and my ping dropped for atleast 4 days back to 16ms, then each day it went up again. I must be honest my connection is more stable than what is was 2 months ago, I just don't understand why my ping keeps going up to around 38-49 but never any higher. Also the noise margin on my router is still around 9.1 up from 5.9db.
C:\Users\St3>ping plusnet.net
Pinging plusnet.net [91.237.88.232] with 32 bytes o
Reply from 91.237.88.232: bytes=32 time=61ms TTL=50
Reply from 91.237.88.232: bytes=32 time=56ms TTL=50
Reply from 91.237.88.232: bytes=32 time=58ms TTL=50
Request timed out.
Ping statistics for 91.237.88.232:
Packets: Sent = 4, Received = 3, Lost = 1 (25%
Approximate round trip times in milli-seconds:
Minimum = 56ms, Maximum = 61ms, Average = 58ms
C:\Users\St3>ping bbc.co.uk
Pinging bbc.co.uk [212.58.246.103] with 32 bytes of data:
Reply from 212.58.246.103: bytes=32 time=37ms TTL=56
Reply from 212.58.246.103: bytes=32 time=38ms TTL=56
Ping statistics for 212.58.246.103:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 37ms, Maximum = 38ms, Average = 37ms
