So whats actully happening to customers broadband speeds?
- So whats actully happening to customers broadband ...
Re: So whats actully happening to customers broadband speeds?
11-04-2014 3:42 PM
11-04-2014 4:24 PM
I've just increased the profile on our side to 13500kbps (i.e to match the current BT one)
I'll check in with you again on Monday if that's OK to see how things have progressed and if the fault ticket needs picking up.
11-04-2014 4:33 PM
I had a router placed near my old plasma, every time the tv was on, I would get 3 - 4meg less throughput than normal, on both wireless AND wired.
11-04-2014 4:51 PM
@ Adam
Ok mate thanks! Early days but webpages seams to me opening faster than 30 mins ago, fingers crossed things get better!
13-04-2014 6:28 PM
14-04-2014 12:35 PM
14-04-2014 3:33 PM
14-04-2014 5:55 PM
14-04-2014 11:53 PM
15-04-2014 9:04 AM
15-04-2014 9:06 AM
Can you do a command line ping to bbc.co.uk or similar, this will give more consistent results than speedtest.net
15-04-2014 1:47 PM
Pinging bbc.co.uk [212.58.244.20] with 32 bytes of data:
Reply from 212.58.244.20: bytes=32 time=37ms TTL=56
Reply from 212.58.244.20: bytes=32 time=38ms TTL=56
Ping statistics for 212.58.244.20:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 37ms, Maximum = 38ms, Average = 37ms
15-04-2014 3:42 PM
Reply from 212.58.244.20: bytes=32 time=376ms TTL=56
Reply from 212.58.244.20: bytes=32 time=424ms TTL=56
Reply from 212.58.244.20: bytes=32 time=78ms TTL=56
Minimum = 37ms, Maximum = 424ms, Average = 228ms
C:\Users\St3>ping bbc.co.uk
Reply from 212.58.244.20: bytes=32 time=57ms TTL=56
Reply from 212.58.244.20: bytes=32 time=42ms TTL=56
Minimum = 38ms, Maximum = 57ms, Average = 48ms
Reply from 212.58.244.20: bytes=32 time=73ms TTL=56
Minimum = 37ms, Maximum = 73ms, Average = 46ms
Reply from 212.58.244.20: bytes=32 time=36ms TTL=56
Reply from 212.58.244.20: bytes=32 time=43ms TTL=56
Minimum = 36ms, Maximum = 43ms, Average = 38ms
Just replaced network cables with new to rule out any faults, again im going to monitor the connection for another day
this speedtest was taken after I ran the ping tests in cmd.
so its kinda up and down, but not where it should be which is around 15-25 max.
15-04-2014 10:32 PM
16-04-2014 8:26 AM
Pinging bbc.co.uk [212.58.246.103] with 32 bytes of data:
Reply from 212.58.246.103: bytes=32 time=695ms TTL=56
Reply from 212.58.246.103: bytes=32 time=583ms TTL=56
Reply from 212.58.246.103: bytes=32 time=288ms TTL=56
Reply from 212.58.246.103: bytes=32 time=525ms TTL=56
Ping statistics for 212.58.246.103:
Minimum = 288ms, Maximum = 695ms, Average = 522ms
This next test is taken 1 min after the first one
Pinging bbc.co.uk [212.58.246.104] with 32 bytes of data:
Reply from 212.58.246.104: bytes=32 time=39ms TTL=56
Ping statistics for 212.58.246.104:
Minimum = 39ms, Maximum = 39ms, Average = 39ms
Any ideas on what could be wrong adam ? When you reset my line last Friday my connection slowly got better and for 24 hours I had aping of 21 which was looking great then after 24 hours the ping started to go up again.
