So whats actully happening to customers broadband speeds?
St3
Aspiring Champion
Fixes: 5
Today I have a ping of 38 and speeds of 10 meg down, since the start of last month I noticed drop outs then high pings and a reduction in speeds. 3 months ago I had a stable connection with 14 meg down and a ping of 15-20 which was great but im slowly noticing a change.
But ive also been noticing a lot of other customers posting about the same issues, anyone think theres something fishy going on ?
My ip profile was 14 meg then 13 meg last week it was 12 meg and now its 11.02 Mbps its going down bit by bit Sad
64 REPLIES 64
Chris
Legend
Fixes: 169
Re: So whats actully happening to customers broadband speeds?
That sounds like the quality of your line has degraded, or something has caused noise and the SNR has crept up. We can't directly affect the IP profile, this is worked out from the sync speed on your line.
Raise a fault at faults.plus.net and we'll take a look.
St3
Aspiring Champion
Fixes: 5
chris check this speed recorded a few mins ago
Ive replaced all my filters with new ones and will do a test on the test socket tomorrow as this means moving my whole pc, pain in the backside but I think ill give it a clean out while doing so.
Ive just rebooted my router my download speeds have gone upto 10 meg but my ping is very high still.
If the test socket still gives me poor speeds and high pings then ill open a support ticker tomorrow.
St3
Aspiring Champion
Fixes: 5
chris the noise margin on my router status is creeping up now its at 12.6db if you reset the line are u able to lower that ? I think it used to be around 6
St3
Aspiring Champion
Fixes: 5
im struggling to add a screenshot on here, if this works chris take a look at router status for me, btw 2 weeks ago I had a lot of drop outs and plusnet support reset my line they rasied the db level from 3 to 6 db but as you can see its now at 12.3 sometimes 12.9. Are you able to turn that back down to see if it helps any ? Or even try another line reset.
adamwalker
Fixes: 221
I'm seeing some drops over the past day or two but I'm wondering if any of those might have been yourself rebooting the router?
I've submitted the SNR reset so lets see how things go with that to begin with.
Glad to see you've raised a fault so we can pick things up after the reset has processed if need be.
I'll check back in a few minutes to see if the profile needs to be updated:
<img src="http://community.plus.net/visualradius/generated/image13972246197765.png"/>
 Adam Walker
thesawdust
Such high SNR prolly is because interleaving has been enabled?
A reset will put you back on a 6dB profile, however if it creeps up again then a fault should be raised
St3
Aspiring Champion
Fixes: 5
I think interleaving is on but its always been fine up until the last 2 months.
well adam my ping is back to a normal rate, but my router shows 15meg down it was always around 14-15 max so that's ok but the router shows that but speedtest shows only 10. Btw adam I have rebooted the router twice now and jumped gateways a couple of times trying to find a solution.
St3
Aspiring Champion
Fixes: 5
thesawdust
Are you doing the test via wireless or wired?
Also if you keep rebouting/gateway hopping will cause DLM to think the line has an fault and you'll get slapped with interleaving/reduced sync speeds.  Roll_eyes
St3
Aspiring Champion
Fixes: 5
Just wondering if my ip profile also needs upping ?
wired test btw, I know about rebooting/gateway hopping I only do this when I think I really have too Wink
St3
Aspiring Champion
Fixes: 5
yes im aware of what happens if I reboot, its something I tend not to do unless need too.
thesawdust
Well, if Adam has reset the line then there is nothing they can do about BT's profile. Try not rebooting and see if profile catches up  Smiley
St3
Aspiring Champion
Fixes: 5
Im sure they can do something to increase the profile because it was once done when I first joined plusnet
Btw I took this speedtest in feb look at difference in my speeds to what they are today, this proves somthings wrong somewhere
thesawdust
PlusNET can not increase Profiles, I believe the system sets the profile on the line
The profile should catch up providing the line is stable, that means no gateway hopping  Tongue
