So what happened around 6.30PM 17/7
Fixes: 341
Just perusing the broadband ping graphs and it seems a few of us had a drop around 6.30pm did a gateway drop?
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
RichardB
Fixes: 5
Re: So what happened around 6.30PM 17/7
In my case browsing was very slow & pages not fully appearing so I manually disconnected & hopped gateways.
This was brought an instant improvement - all back to normal.
I think I was a PCL-?? gateway before the hop & I am now on  PTN-AG01.
No drop here, I was watching a twitchtv stream at that time.
ptn-ag04
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Mine is one of those showing that 'drop' but router log does not show any loss of ppp session.  Undecided
Call me 'w23'
There was a brief issue lasting a couple of minutes on a couple of the PCL gateways that would have caused this.
Fixes: 341
thanks for that update Chris Smiley
Fixes: 62
and look what it did to my pings
Fixes: 166
Not sure what I'm looking for here Jim? The very brief glitch was at 6.30pm your minimum latency changed around 5am the following morning.
 Chris Parr
 Plusnet Staff
Fixes: 62
Embarrassed needs to go to Specsavers - missed the PM
Fixes: 4
A graph for you to ponder over  Smiley
