So it seems my internet is playing up again
ListerofSmeg
I first noticed on the connection had dropped after checking into the router and seeing all my stats had been reset and literally the net just dropped again.
This is what the router says:
Jan 16 15:35:55 user crit kernel: ADSL link down
Jan 16 15:35:56 user crit kernel: ADSL G.994 training
Jan 16 15:35:57 daemon crit pppd[14760]: Clear IP addresses. Connection DOWN.
Jan 16 15:35:57 daemon crit pppd[14760]: Clear IP addresses. PPP connection DOWN.
Jan 16 15:36:03 user crit kernel: ADSL G.992 started
Jan 16 15:36:08 user crit kernel: ADSL G.992 channel analysis
Jan 16 15:36:14 user crit kernel: ADSL G.992 message exchange
Jan 16 15:36:15 user crit kernel: ADSL link down
Jan 16 15:36:20 user crit kernel: ADSL G.994 training
Jan 16 15:36:27 user crit kernel: ADSL G.992 started
Jan 16 15:36:31 user crit kernel: ADSL G.992 channel analysis
Jan 16 15:36:37 user crit kernel: ADSL G.992 message exchange
Jan 16 15:36:37 user crit kernel: ADSL link up, interleaved, us=528, ds=2602
Jan 16 15:36:49 user crit kernel: ADSL link down
Jan 16 15:36:51 user crit kernel: ADSL G.994 training
Jan 16 15:36:58 user crit kernel: ADSL G.992 started
Jan 16 15:37:02 user crit kernel: ADSL G.992 channel analysis
Jan 16 15:37:09 user crit kernel: ADSL link down
Jan 16 15:37:15 user crit kernel: ADSL G.994 training
Jan 16 15:37:21 user crit kernel: ADSL G.992 started
Jan 16 15:37:26 user crit kernel: ADSL G.992 channel analysis
Jan 16 15:37:32 user crit kernel: ADSL G.992 message exchange
Jan 16 15:37:32 user crit kernel: ADSL link up, interleaved, us=531, ds=2380
Jan 16 15:37:36 daemon crit pppd[14760]: PPP LCP UP.
Jan 16 15:37:37 daemon crit pppd[14760]: Received valid IP address from server. Connection UP.
This evening:
Jan 16 18:24:15 user crit kernel: ADSL link down
Jan 16 18:24:17 user crit kernel: ADSL G.994 training
Jan 16 18:24:18 daemon crit pppd[14760]: Clear IP addresses. Connection DOWN.
Jan 16 18:24:18 daemon crit pppd[14760]: Clear IP addresses. PPP connection DOWN.
Jan 16 18:24:24 user crit kernel: ADSL G.992 started
Jan 16 18:24:28 user crit kernel: ADSL G.992 channel analysis
Jan 16 18:24:35 user crit kernel: ADSL link down
Jan 16 18:24:40 user crit kernel: ADSL G.994 training
Jan 16 18:24:47 user crit kernel: ADSL G.992 started
Jan 16 18:24:52 user crit kernel: ADSL G.992 channel analysis
Jan 16 18:24:58 user crit kernel: ADSL G.992 message exchange
Jan 16 18:24:58 user crit kernel: ADSL link up, interleaved, us=371, ds=2624
Jan 16 18:25:02 daemon crit pppd[14760]: PPP LCP UP.
Jan 16 18:25:08 daemon crit pppd[14760]: Received valid IP address from server. Connection UP.
Jan 16 18:26:02 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/38.
Jan 16 18:26:04 user crit kernel: OAM loopback response not received on PORT/VPI/VCI 0/0/38.
Router stats:
SNR Margin (dB): 3.1  8.0
Attenuation (dB): 65.0  38.2
Output Power (dBm): 13.0  0.0
Attainable Rate (Kbps): 3356  416
Rate (Kbps): 2624  371
BT Speedtest: 2.31 Mbps, IP Profile for your line is - 2.1 Mbps. U/L 0.3Mbps
Plusnet: Current line speed:    2.2 Mb
If the drops are caused by the clight speed increase, I would much rather have my default 2.1Mb which was until now solid.
