Snail slow Plusnet Unlimited
BigNez
After frequent disconnections we now have 1.5 Mbps broadband!
I have two unhappy teenagers since we moved back onto ASDL2+ and a broken on off switch on the router due to frequent resets!
Fixes: 24
Re: Snail slow Plusnet Unlimited
Frequent disconnections are one problem but your router should cope with that automatically.  If you actually have to power-cycle the router to clear the problem and re-establish the connection then either your router is faulty or your line is faulty.  Report it as a fault.
BigNez
I have again reported this. The maximum number of tickets is Four so I had to phone.
My own router is faulty due to the constant power cycling but as I was a fiber customer the supplied cable router is not completable with ASDL.
Fixes: 69
Sorry to hear that's still a problem for you BigNez you've raised a fault which is the right thing to do so we'll get back to you about that ASAP.
 Adam Walker
