Snail slow Plusnet Unlimited
- Re: Snail slow Plusnet Unlimited
16-08-2012 11:04 PM
After frequent disconnections we now have 1.5 Mbps broadband!
I have two unhappy teenagers since we moved back onto ASDL2+ and a broken on off switch on the router due to frequent resets!
Message 1 of 4
(1,212 Views)
3 REPLIES 3
16-08-2012 11:12 PM
Frequent disconnections are one problem but your router should cope with that automatically. If you actually have to power-cycle the router to clear the problem and re-establish the connection then either your router is faulty or your line is faulty. Report it as a fault.
Message 2 of 4
(492 Views)
17-08-2012 9:04 AM
I have again reported this. The maximum number of tickets is Four so I had to phone.
My own router is faulty due to the constant power cycling but as I was a fiber customer the supplied cable router is not completable with ASDL.
Message 3 of 4
(492 Views)
17-08-2012 11:12 AM
Message 4 of 4
(492 Views)
