Snail pace speeds
- Re: Snail pace speeds
Snail pace speeds
15-01-2013 11:37 AM
speed checker says
Download speedachieved during the test was - 1.67 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
15-01-2013 11:40 AM
I assume that your exchange isn't 21CN enabled http://usertools.plus.net/exchanges/
15-01-2013 11:45 AM
It's not a stuck profile. The profile on our side is at 7150, which is correct. Was the router connected to your computer via a wired or wireless connection?
Incidentally for Oldjim's info the exchange isn't 21CN enabled.
15-01-2013 11:46 AM
The reported IP profile from the BT speed test is 2Mb which I think is stuck
15-01-2013 11:51 AM
15-01-2013 12:03 PM
15-01-2013 1:48 PM
Quote from: _Adam_Walker_ It's a stuck profile on BT's side not ours.
I'll raise an SNR reset now, that should take effect in a few hours time, if not I'd advise raising a fault.
It may be stuck on a fixed profile of 2Mb? I know the missus was on a fixed 2Mb datastream connection and we had to raise a ticket to get her on to adsl max.
15-01-2013 2:42 PM
Where did Jim suggest it was on your side? If you had looked at the results from the BT speed test you'd have recognised it as a 20CN test and seen the 2MB IP Profile which is a classic sign of a stuck BT profile which Jim recognised.
15-01-2013 2:53 PM
Its is a stuck profile on BT's side, the 20CN SNR reset I've submitted should fix that.
17-01-2013 8:51 AM
17-01-2013 8:57 AM
See this thread for how to get this information http://community.plus.net/forum/index.php/topic,96155.0.html
Oh, scratch that, you're at about top speed for 20CN.
17-01-2013 8:59 AM
17-01-2013 9:03 AM
