Smart tv can't connect to plusnet wifi
stuartallen1874
I am unable to connect our smart tv to the network, never had this issue with previous provider.
The Wi-Fi connects to all other devices and speed is fine, it's just the tv.
It won't even find the network when searching.
Any help is appreciated.
6 REPLIES 6
Legend
Fixes: 232
Re: Smart tv can't connect to plusnet wifi
What make/model TV?
stuartallen1874
It's an LG webOS
Legend
Fixes: 232
Have you successfully connected it previously? Have you tried resetting it to default?
stuartallen1874
Never had the issue with sky. Just changed to plus net and then this happens.
Legend
Fixes: 232
As I asked - have you tried resetting the TV? It may still be looking for the SKY connection.
TheMightyAJ
Fixes: 126
Hey @stuartallen1874,
I'm very sorry to hear that you've encountered this issue. Have you had a chance to try connecting the TV via Ethernet cable, to see if that works?
 Alex H
