Smart tech
emmajr2005
Smart tech
Hey guys I have smart tech light bulb and robovac they both run off 2.4ghz I have both 2.4 and 5ghz how do I connect using the 2.4 and not the 5. Do I have to turn the 5 off? Will it effect my speed? Please help as so far my light and robovac won't connect thanks
Tags (1)
2 REPLIES 2
Fixes: 388
Re: Smart tech
@emmajr2005 Welcome to the forums. To connect the 2.4Ghz devices, temporality turn the 5Ghz band off while connecting them, and then turn it back on.
emmajr2005
Re: Smart tech
Great I will try once my son has finished watching the footy ty
