Smart TV can`t connect through - help please!
- Re: SMART TV CAN`T CONNECT THROUGH - HELP PLEASE!
01-07-2013 8:33 PM
jim:red All capos in title changed as per this Forum Rule mod:end
01-07-2013 8:35 PM
Re: Smart TV can`t connect through - help please!
01-07-2013 9:17 PM
See below for the information that comes up. I want to alter the IP address but cant overtype it or edit it.
Unknown-c0-d9-62-89-fd-57
Information
Physical Address: c0:d9:62:89:fd:57
IP Address Assignment: Static
IP Address: 0.0.0.0
01-07-2013 9:20 PM
Quote from: pauljbloor I have been told to set up a manual IP for the TV so my router will give it permission to connect through to the internet,
By who, that's total twaddle.
Wrong.
Quote from: pauljbloor IP Address Assignment: Static
01-07-2013 9:42 PM
01-07-2013 9:45 PM
Quote from: gtowen Hopefully someone more knowledgeable will come along soon, but until then try disconnecting your tv from the router and reconnecting. Maube then the dhcp server in the router will assign an ip address to the tv.
It won't do that until the error highlighted above is corrected.
The IP setting should be Dynamic via DHCP (or whatever equivalent wording the TV settings use).
01-07-2013 9:48 PM
01-07-2013 9:49 PM
01-07-2013 9:58 PM
01-07-2013 9:58 PM
01-07-2013 10:05 PM
Unless there's someone here with the exact same TV you're going to have to find out how to change stuff for yourself and tell people here what options the manual gives you in relevant areas.
01-07-2013 10:07 PM
02-07-2013 12:56 PM
02-07-2013 1:11 PM
Quote from: pauljbloor I think it is set up to Auto
This says otherwise, unless you've changed it since.
02-07-2013 1:23 PM
