Sluggish?
- Sluggish?
Sluggish?
23-09-2009 12:59 PM
My wfie said last night that things seemed sluggish. Today its been a bit odd with sites seemingly taking a while to load. A speed test shows
I managed to get a Wireshark capture which I've put at http://www.tty.org.uk/bbc but apart from a couple of Out-of-Orders and a couple of re-transmissions I can't see anything glaringly wrong apart from the huge delay at the start (but I'm no Wireshark expert).
Message 1 of 7
(2,415 Views)
6 REPLIES 6
Re: Sluggish?
30-09-2009 5:24 PM
Thanks for the Wireshark Steve, if you ever link to them in future though, it's probably best to save the captures as .pcap files as it makes them much easier to read at this end.
Message 2 of 7
(847 Views)
Re: Sluggish?
30-09-2009 5:45 PM
OK no problems, I'll try to remember that
Message 3 of 7
(847 Views)
Re: Sluggish?
01-10-2009 10:15 PM
33 seconds to load the front page at www.livejournal.com?
Something is very wrong... and again I got immediate DNS response then it just seemed to sit round waiting.
Now which pcap format from the Linux wireshark capture do I need to save it in?
Message 4 of 7
(847 Views)
Re: Sluggish?
01-10-2009 10:29 PM
It is horribly slow - here is a wireshark capture http://www.holtlane.plus.com/files/livejournal.pcap
and a tracert which shows some slow hops
Tracing route to www.livejournal.com [208.93.0.128]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 58 ms 42 ms 49 ms lo0-plusnet.pcl-ag04.plus.net [195.166.128.134]
3 44 ms 47 ms 41 ms gi1-6-604.pcl-gw02.plus.net [84.92.0.229]
4 40 ms 39 ms 39 ms te2-1.pcl-gw01.plus.net [212.159.1.113]
5 39 ms 39 ms 42 ms xe-1-2-0-0.lon20.ip4.tinet.net [213.200.79.233]
6 123 ms 128 ms 121 ms xe-4-3-0-0.was12.ip4.tinet.net [213.200.80.25]
7 120 ms 118 ms 117 ms dcp-brdr-03.inet.qwest.net [63.146.26.17]
8 158 ms 163 ms 158 ms dvr-core-01.inet.qwest.net [67.14.24.17]
9 200 ms 195 ms 198 ms bil-core-02.inet.qwest.net [205.171.8.154]
10 218 ms 195 ms 196 ms bil-edge-02.inet.qwest.net [205.171.154.22]
11 197 ms 206 ms 197 ms 65.121.112.210
12 196 ms 196 ms 208 ms livejournal.com [208.93.0.128]
Trace complete.
Trace complete.
Message 5 of 7
(847 Views)
Re: Sluggish?
01-10-2009 10:31 PM
about 10 seconds on 21cn
@oldjim like me then leave routerstats monitoring 24/7
1 1 ms 6 ms 1 ms 10.0.0.1
2 17 ms 17 ms 24 ms lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3 17 ms 16 ms 19 ms vl604.thn-gw2.plus.net [84.92.4.170]
4 17 ms 17 ms 19 ms ldn-b4-link.telia.net [213.248.84.197]
5 18 ms 18 ms 18 ms ldn-bb1-link.telia.net [80.91.250.234]
6 97 ms 93 ms 93 ms ash-bb1-link.telia.net [213.248.65.98]
7 136 ms 94 ms 96 ms qwest-119092-ash-bb1.telia.net [213.248.88.178]
8 148 ms 146 ms 147 ms dvr-core-01.inet.qwest.net [67.14.24.17]
9 174 ms 172 ms 172 ms bil-core-02.inet.qwest.net [205.171.8.154]
10 172 ms 172 ms 173 ms bil-edge-02.inet.qwest.net [205.171.154.22]
11 172 ms 172 ms 173 ms 65.121.112.210
12 174 ms 173 ms 173 ms livejournal.com [208.93.0.128]
Message 6 of 7
(847 Views)
Re: Sluggish?
02-10-2009 3:39 PM
Those traceroutes look like the slowdown is happening at the qwest end.
Is it cross atlantic?
Message 7 of 7
(847 Views)
