Slowness in my broadband speed
- Re: Slowness in my broadband speed
28-05-2010 12:56 PM
I have started using Plusnet since 9th Jan 2010.The service and speed is good, but suddenly from last 5 days my broadband is too slow and even not able open mail box.Done the speedtesting using btspeedtester it shows results as below average. I called plusnet customer care on Monday and advised me to wait 3 days.But nothing changed after 3 days also still same low speed....don't know all of a suddenly speed gone down..strange..Can anyone help me please?
Thanks,
Gilla
Thanks,
Gilla
Message 1 of 7
(1,117 Views)
6 REPLIES 6
28-05-2010 4:51 PM
1. Is your router switched on/powered up 24/7..... it should be..
2. have you tried to re-boot your router - i.e. power down, leave for 15 minutes then power back up and let it re-connect?
3. If you haven`t re-booted..... I suggest you do so, but only do it between 10:00 and 15:00 (and do it only once.)
4. after re-boot do a speed test, and then post the results.
5. can you access your "router stats"? if so, post them with the speed test result.
Message 2 of 7
(600 Views)
28-05-2010 4:58 PM
Hmm everything appears ok from our side, you had an intermittent connection for a few days but that now seems to have cleared up. Your line profile is set at 9000 and you should be seeing much much higher speeds than you are currently getting. Can you try logging in to your router control panel and asking it to disconnect/reconnect?
Message 3 of 7
(600 Views)
30-05-2010 8:52 PM
Hey Hey My lovely Plusnet is back...Thanks a lot all.....Now my speed is back and working perfectly from yesterday onwards. :)...but still curious to know what caused my low speed suddenly..
Message 4 of 7
(600 Views)
30-05-2010 8:55 PM
I used to switchoff my router before going to bed...might be the reason for sudden drop in slowness...
Message 5 of 7
(600 Views)
30-05-2010 9:30 PM
YAY !... result ! ! !...
leave the router switched on 24/7 unless you get a really close lightning storm, and then I would unplug everything ! ! !...
Message 6 of 7
(600 Views)
30-05-2010 9:36 PM
Could it have been congestion at the exchange?
Message 7 of 7
(600 Views)
