Slowing Speed
JAYELL
Slowing Speed
Hi, I have been with Plusnet for about 6 months now and never had any problems. But over time my download speed has dropped from a steady 14+ to 9.9/10. that is not too bad for emails etc. but lately I am getting an increase in buffering with Netflix.  ITV catch up is unwatchable now. I was promised and got 14+ when I first came to PN but now it has reduced and nothing has changed at my end. Is this temporary or am I stuck with 10mbps
adie:red removed all caps title as per link:rules]
JAYELL
Re: Slowing Speed
There is no crackling on my line.
the BTW test show similar results
Fixes: 162
Re: Slowing Speed
Thanks for the tests and for checking the line for noise.
Your line seems very stable, no disconnections in 19 days.
Your line profile is already at the best setting for speed:
WBC 160K - 24M No delay (INP 0) 3dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+)
Although the target SNR is 3db, your current SNR is 7.5.
Can you try logging in to the router, disconnecting, remove the DSL cable, wait 30 seconds, plug it back in and reconnect.
 Chris Parr
 Plusnet Staff
JAYELL
Re: Slowing Speed
thank for the reply.
I did that. latest BTW test was 10.95mbps  and  0.72mbps
JAYELL
Re: Slowing Speed
I will give Netflix etc a go tonight to see if it has improved.
Fixes: 203
Re: Slowing Speed
Those results look fine.
Let us know how you get on.
 Matthew Wheeler
JAYELL
Re: Slowing Speed
Sorry about the delay getting back in touch.
The download is now 11.06mbps and netflix etc was fine last night.  Smiley
For future reference, if it slows down again is it OK it disconnect the router as instructed?
"Can you try logging in to the router, disconnecting, remove the DSL cable, wait 30 seconds, plug it back in and reconnect."
Fixes: 25
Re: Slowing Speed
Hi John,
A warm welcome to the forums.
In short absolutely NO!!!  Cool
Quote from: Chris
This statement potentially points to an issue to be watched.  Chris' advice was specifically relevant to this observation, random reboots of the ADSL router is not good practice, even though some will seek to claim that it does not really matter.
The above observation somewhat points to the possibility of interference on the line.  I suspect that you will be back again with another report of speed issues, which we can look at then.
In the time that things deteriorated, have you bought any new electrical equipment?
Take a look at the speed issues thread and work through the problem elimination activities.  Sight of the router stats would be useful please.  Is the phone line quiet?  Are there any phone extensions, if yes how are they wired?
Kevin
