Slower speeds in last few months.
davidwright6
Hello. I have been with Plusnet for around 5 years if im not mistaken now, and in that time my connection speed has always been 2mb-2.5mb. However in the last few months i have not been able to connect at anything higher than about 1700-1800kbps? nothing has changed on my end, i am still plugged into maser socket with shortest cable i have, have tried using new filters, and i have 2 separate routers which i have swapped to try and get the faster speed back. No luck though. I cant understand it. There is a second internet connection to this same property, (plusnet also) and that connection was 2mb+ yesterday when i tried it, so how come mine is not?
Internet has been very slow last few days after rebooting my router too many times and getting a dropped line IP. managed to connect at 1800kbps and have left it like that for last 3 days to rise the line IP again, but i simply am not getting the speed i was getting(before i signed a 2year contract)
9 REPLIES 9
adamwalker
Fixes: 221
Re: Slower speeds in last few months.
It looks like an SNR reset should resolve this for you. I've just submitted one now which should complete within the next 4 hours.
Let us know if there's any issues beyond that.
Adam
 Adam Walker
davidwright6
thank you, does this require me to reboot my router or anything or do i just wait?
davidwright6
just reset the router in the test socket. SNR has gone UP now and speed has gone even SLOWER after waiting for 3 days for line ip to increase..... tried 2 resets but only connecting at 1500kbps.
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:04:24
Downstream: 1.563 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 13.0 dB / 12.0 dB
Line attenuation (Down/Up): 56.0 dB / 31.5 dB
Output power (Down/Up): 17.6 dBm / 12.5 dBm
FEC Events (Down/Up): 9 / 0
CRC Events (Down/Up): 1 / 0
HEC Events (Down/Up): 0 / 0
Error Seconds (Local/Remote): 1 / 0
davidwright6
If i cant get this sorted in the next couple of weeks I would like to talk about cancelling my contract with you on the grounds that i haven't been receiving the product i thought i was signing up for. I already pay more than most, for much much slower speeds. In any other industry that would not be allowed to happen.
adamwalker
Fixes: 221
@davidwright6,
Sorry to hear you're having further issues with this. Diagnostics are showing that the attenuation for your line is quite high. Are you having any issues using the phone (i.e any noise audible on the line?).
 Adam Walker
davidwright6
I never use a phone on this line, but have just plugged one in, and line sounds ok.
Connection time: 0 days, 01:47:01
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Noise margin (Down/Up): 15.1 dB / 12.0 dB
FEC Events (Down/Up): 4813492 / 24
CRC Events (Down/Up): 16 / 2
HEC Events (Down/Up): 40 / 1
Error Seconds (Local/Remote): 11 / 3
davidwright6
If you just did something, my router just synced at 3mb so thanks, but i think the IP profile is still holding me back at 1.25-1.5mb
Chris
Legend
Fixes: 169
The IP profile has now updated to 2500, and I've just kicked the profile on our side up to match it too. If you don't see an improvement in speeds shortly, try logging in to the router and disconnect/reconnect.
davidwright6
brilliant!, seems to have worked thank you very much.  Grin
