Slower max speed
- Slower max speed
Slower max speed
19-05-2012 10:25 PM
I have been syncing at 8128 kbps Downstream & 448 kbps Upstream, sometimes both these have been lower but i was still able to get a 4700kbps Download speed.
I have tried all the usual router resets, replaced the filter, left the router for 9/10 days but still have not returned to my usual max Download of over 6000kbps.
I have noticed some fluctuation in SNR both up and down and perhaps this has caused my max speed to become stuck or lowered.
Broadband Speed Tests have also been erratic, one gave a download of 13000kbps another of 9000kbps from 2 different sites
My BT Speed Tester IP profile has also been lowered at times but is now back at 7.15
My Plusnet Current Line speed is 5 MB
Netgear DGN2200 Router Stats
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN pppoa 43418 60300 0 531 6475 03:10:04
LAN1 10M/100M 9669771 6938574 0 1781 1080 03:23:57
LAN2 Link Down --
LAN3 10M/100M 08:33:12
LAN4 Link Down --
WLAN 145M 745206 542944 0 1578 126 6 days 14:09:36
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 25.0 db 13.0 db
Noise Margin 6.2 db 16.0 db
My Broadband Speed Test
Today 22:07 4736 kbps (592kB/s) 382 kbps (47.8kB/s) Share
Tuesday 21:39 4855 kbps (607kB/s) 377 kbps (47.1kB/s) Share
May 12, 22:22 4699 kbps (587kB/s) 381 kbps (47.6kB/s) Share
May 8, 22:00 4875 kbps (609kB/s) 382 kbps (47.8kB/s) Share
May 8, 21:33 4742 kbps (593kB/s) 381 kbps (47.6kB/s) Share
May 8, 21:13 4476 kbps (560kB/s) 379 kbps (47.4kB/s) Share
May 8, 21:08 4718 kbps (590kB/s) 262 kbps (32.8kB/s) Share
May 8, 21:06 4752 kbps (594kB/s) 381 kbps (47.6kB/s) Share
May 8, 21:05 4837 kbps (605kB/s) 379 kbps (47.4kB/s) Share
May 8, 19:52 4703 kbps (588kB/s) 380 kbps (47.5kB/s) Share
May 8, 09:56 4702 kbps (588kB/s) 379 kbps (47.4kB/s) Share
May 7, 21:48 4741 kbps (593kB/s) 382 kbps (47.8kB/s) Share
May 7, 11:49 4720 kbps (590kB/s) 382 kbps (47.8kB/s) Share
May 6, 21:42 6956 kbps (870kB/s) 382 kbps (47.8kB/s) Share
May 6, 11:39 4721 kbps (590kB/s) 378 kbps (47.3kB/s) Share
May 5, 21:56 4720 kbps (590kB/s) 319 kbps (39.9kB/s) Share
May 4, 22:06 4723 kbps (590kB/s) 380 kbps (47.5kB/s) Share
May 4, 21:53 4732 kbps (592kB/s) 354 kbps (44.3kB/s) Share
May 4, 21:52 4817 kbps (602kB/s) 371 kbps (46.4kB/s) Share
May 2, 21:08 4387 kbps (548kB/s) 376 kbps (47kB/s) Share
May 1, 21:43 4732 kbps (592kB/s) 381 kbps (47.6kB/s) Share
Apr 29, 20:29 4670 kbps (584kB/s) 379 kbps (47.4kB/s) Share
Apr 29, 19:54 4707 kbps (588kB/s) 372 kbps (46.5kB/s) Share
Apr 27, 19:22 4706 kbps (588kB/s) 378 kbps (47.3kB/s) Share
Apr 26, 20:45 1960 kbps (245kB/s) 382 kbps (47.8kB/s) Share
Apr 26, 18:15 1964 kbps (246kB/s) 382 kbps (47.8kB/s) Share
Apr 26, 11:38 2017 kbps (252kB/s) 382 kbps (47.8kB/s) Share
Apr 25, 18:06 1949 kbps (244kB/s) 380 kbps (47.5kB/s) Share
Apr 25, 16:21 1951 kbps (244kB/s) 381 kbps (47.6kB/s) Share
If you could look into this i would be most grateful
Richard
Re: Slower max speed
19-05-2012 10:28 PM
Perhaps a more important question is why you are getting these speed fluctuations as you appear to be having sync problems.
You haven't got a Sky Box connected have you
19-05-2012 11:03 PM
Will wait till folk are back at their desks on Monday and see what transpires
Thanks Oldjim
20-05-2012 6:15 AM
Definitely the problem, needs a nice Plusnet person to up it to match your BT IP profile.
Quote My Plusnet Current Line speed is 5 MB
20-05-2012 7:37 AM
BT Speed Tester Results as of 7:30am
Download speedachieved during the test was - 4.57 Mbps
For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
Additional Information:
Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 7.15 Mbps
Today 07:34 4719 kbps (590kB/s) 381 kbps (47.6kB/s
Router at 7:30am
System Up Time 6 days 23:52:44
WAN pppoa 9605 14278 0 41 397 12:52:54
LAN1 Link Down 16596083 11910912 0 4340 1713 --
LAN2 Link Down --
LAN3 10M/100M 6 days 23:52:44
LAN4 Link Down --
WLAN 145M 766288 558428 0 1529 122 6 days 23:52:26
Noise Margin 6.9 db 15.0 db
20-05-2012 6:42 PM
System Up Time 7 days 10:50:31
WAN pppoa 77868 113933 0 331 6607 06:08:09
LAN1 10M/100M 16726624 12014123 0 4317 1629 1 day 00:04:34
LAN2 Link Down --
LAN3 10M/100M 10:19:33
LAN4 Link Down --
WLAN 145M 799923 580055 0 1474 121 7 days 10:50:13
Line Attenuation 26.0 db 13.0 db
Noise Margin 8.2 db 15.0 db
20-05-2012 6:48 PM
i finnish with BT friday and go on line with PN...
I just hope the speed will be ok as now!
20-05-2012 9:17 PM
Don't worry, you shouldn't have a problem as long as your line is ok at the moment. Richard682e's issue is a simple matter of updating a profile.
21-05-2012 8:08 AM
21-05-2012 1:34 PM
Your BT side profile had moved back to 7150 on the 19th, not sure why ours was behind but I've just set it back to 7150 and hope that sorts things for you.
21-05-2012 4:28 PM
Speeds now better and Plusnet Line Profile is up from 5M B to 7.15 MB
