Slow wireless speed on fibre
NickBloodworth
I've just upgraded to fibre (mainly for the download limit), but can't get above 35Mb in wireless - I get 75Mb on wired.
Is there anything on the router I need to do to increase the speed?
My new laptop says it's an "n" router, like the router.
Nick
Fixes: 69
Re: Slow wireless speed on fibre
You might notice from other similar threads such as this one: http://community.plus.net/forum/index.php/topic,109766.0.html that wireless speeds do vary depending on the distance from the router and aren't ever likely to match speeds achieved over ethernet.
As one person suggests on the same thread wall-mounting the router may help improve signal strength.
 Adam Walker
gofaster
Others suggest that waste bin mounting the router helps... Lips are sealed
Fixes: 4
If your using the Plusnet supplied router  Cry then unplug it, throw it down the loo & treat yourself to a proper router for Xmas. I'm using an Asus RT-N56U & my wireless increased by 70%.  Cheesy
